Question about Ingersoll Rand Air Tools & Compressors
SSR EP100 High A/E discharge Temp
We have stepped through all 4 recommendations in the troubleshooting chart and yet we still get this alarm. It recommends that we make sure the "cooling air discharge" is not blocked, but there is not schematic or exploded view in the ops manual. Can anyone help?
hdpanama
  • 65 Answers
SOURCE: Cant set my compressor to automatic start/stop mode
Sorry, what do you mean it 'blows off',, the relief valve is letting off pressure ? Sounds like you need to replace it with the proper psi Relief valve or just a new one. Then you say it restarts but in your question you say 'Cant set my compressor to automatic start/stop mode' If it is restarting that means it is automatically 'stopping' then automatically 'starting' Please clarify your question.
Posted on Nov 20, 2008
  • 89 Answers
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
compman66
  • 169 Answers
SOURCE: IR EP100 compressor-getting change separator element alarm
Ingersoll-Rand uses a differential pressure switch that should be hooked to the separator tank on the "wet" side of the filter and to the "dry" side of the filter, either to the sump lid or to the bottom side of the minimum pressure valve on top of the sump tank. if it is hooked up down stream of the minimum pressure valve it will not work correctly.
If it does not use this, it reads pressure between 2 transducers on the compressor to determine the pressure drop across the separator filter while the compressor is under load. ou need to determine what system you have first to figure out what the problem is. feel free to contact me through my website for more information
www.morrismachineservicesllc.com
Posted on Dec 16, 2009
  • 17 Answers
SOURCE: our company has ingersoll rand
make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
Posted on Dec 19, 2010
  • 214 Answers
SOURCE: Have a SSR-EP100 air compressor that shows
Try to reset the main motor and fan motor over loads by pushing the reset on the overload it self, Then reset the controller. If the error resets, before starting. put a clamp on amp meter on to L1 or L3 motor lead which is located in the compressor electrical box . Then start and observe amps when unit is making air fully loaded. Once you know how many amps at full load the unit is pulling ,look at the overload setting on main motor overload and see if it is approxmately 10 amps above the max amps being pulled.If not set it about 10 amps above your max load amps.
Posted on Dec 01, 2011
How do I get the message light to stop blinking? Comdial EP100 (I have no messages).
COMDIAL EP100 USER MANUAL Pdf Download.
www.manualslib.com > ... > Telephone > CONVERSip EP100
View and Download Comdial EP100 user manual online. Comdial Corporation User Guide Telephone EP100. EP100 Telephone pdf manual download.
Sep 18, 2015 | Comdial Lands Phones
My ssrxpe60 ingersoll rand compressor is giving a high air pressure alarm and shuts down
I may be missing something here but typically a SSR is a rotary screw machine.XPE 60 is the model. It probably has a controller of some type for this person to know its shutting down on high air pressure alarm. So as the previous person kindly said don't give advise on something you know nothing about before you get some one hurt or killed!!!!
To answer the question. You may have a pressure transducer bad but most likely you have a minimum pressure check valve stuck in the closed position. When the compressor starts air pressure in the separator tank builds. At approximately 65 Psi the MPCV opens and allows air to the after cooler and out into the system. If the MPCV doesn't open the air pressure in the separator tank becomes to high. You then get the high pressure alarm and the unit shuts down.
Make sure the air pressure is zero, electrical disconnected and discharge line isolated from system. Once done you should be able to unscrew the aluminum cap on the check valve. Be extra careful due to spring tension. It should loosen as the cap is removed. If the parts inside are very corroded or you are unable to remove the cap you may have to replace the complete valve. If able to disassemble clean and purchase a rebuild kit for your MPCV if available.
Feb 21, 2015 | Ingersoll Rand Air Tools & Compressors
Toshiba LCD TV TroubleShooting
I had same problem, i just replaced the power capasiters on the board an solved it...look for mushroom heads or bottoms on them an swap them out an it should be it. And if thats it then buy the higher temp capasiters so it wont happen again..
Dec 18, 2011 | Toshiba 42LX196 42 in. LCD HDTV
Ingersoll rand air compressor model SSR-UP5-30-14 frequent trip on high airend temperature ....what is the solution ? and another unit ( same model ) always trip on " starter fault ". Untill...
check if approach and discharge pipes to oil cooler are similar temperature as there is a thermo bypass valve that controls the flow through the cooler if cooler is quite cool but still very hot inside this could be stuck in closed position causing restricted flow through the cooler
Sep 20, 2011 | Ingersoll Air Tools & Compressors
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Feb 12, 2011 | Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Nov 12, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Nov 11, 2008 | Air Tools & Compressors
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
Air Tools & Compressors Logo
81 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
