Question about Pentair Whisperflo 3/4 Hp 115/230v
110 volt want to swtch from 230 to 110 volt
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
See side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Posted on Sep 07, 2014
Hi .. am in a country that has 220V power outlets. What do I need to use my kitchen ais that has 120V, 60hz and a maximum of 330 Watts requirements?
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 04, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I need to install a new AOSmith 1 1/2 horse pump for my pool. The to lines that come from the house are both 110 volt. The pool is wired for 230 volt. Will attaching the 110 lines work for the required...
There is nothing that you can do with respect to the 220 volts vs. 230 volts and fortunately, it does not matter. There is no voltage adjustment that you can do.
The 220 volts comes from TWO DIFFERENT 110 volt lines. Typically, your breaker will handle that correctly for you, be sure that both breakers are bridged, mechanically, so when you turn one off, both go off (prevents electrocution).
Mar 30, 2011 | Pool & Spa
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
POWER SUPPLY PROBLOMS!!!!!!!!
Unless your household electrical service is running at 230 volts, there's absolutely no reason to set your supply for 230. When you choose the 230v setting the supply REQUIRES 230 volts to become operational...Which is not going to happen on a 115 volt service.
Oct 20, 2009 | Compaq Computers & Internet
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
TV PROBLEM
IN MY 230 CHANNEL TOSHIBA KIT WHEN IT IS ON THE 110 VOLTS IS OK. BUT AFTER FEW SECONDS ITS 110 VOLTS BECOME ABOUT 91 VOLTS.WHEN THE VERTICAL SUPPLY RESISTANCE FROM THE EHT,THE VOLTAGE BECOME 110 VOLTS.EHT AND TDA 7698 ARE OK.
Sep 23, 2007 | Televison & Video
POWER SOURCE 110 VERS 230 VT
some times they provide switch for 110/230 at the back side of monitor. but if you do not have that you can purchase converter which converts 110 to 230 volts ac.
Sep 04, 2007 | LG Studioworks 700S 17" CRT Monitor
Pentair Whisperflo 3/4 Hp 115/230v Logo
100 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
