Question about Pentair Whisperflo 3/4 Hp 115/230v
Wiring pump is set to 230 volts never in service and I want to run on 110 volt
    Top Expert:
  • Pentair Master
  • 5,779 Answers
See side of motor it will show you wires to move then hook up for 120 volt
Posted on May 08, 2016
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: my brand new 1.5 hp,
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
Posted on May 29, 2011
110 volt
see side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Gary
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
I need to install a new AOSmith 1 1/2 horse pump for my pool. The to lines that come from the house are both 110 volt. The pool is wired for 230 volt. Will attaching the 110 lines work for the required...
There is nothing that you can do with respect to the 220 volts vs. 230 volts and fortunately, it does not matter. There is no voltage adjustment that you can do.
The 220 volts comes from TWO DIFFERENT 110 volt lines. Typically, your breaker will handle that correctly for you, be sure that both breakers are bridged, mechanically, so when you turn one off, both go off (prevents electrocution).
Mar 30, 2011 | Pool & Spa
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
POWER SUPPLY PROBLOMS!!!!!!!!
Unless your household electrical service is running at 230 volts, there's absolutely no reason to set your supply for 230. When you choose the 230v setting the supply REQUIRES 230 volts to become operational...Which is not going to happen on a 115 volt service.
Oct 20, 2009 | Compaq Computers & Internet
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Pentair Whisperflo 3/4 Hp 115/230v Logo
22 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
