Question about Air Tools & Compressors
Air compressor manual for Brunner model 3249
Model 3249 Serial#320824 Manchester Tank 1996
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
SOURCE: Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Posted on May 04, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
  • 84 Answers
SOURCE: Black Max air compressor (old coleman model)
Needs 30W Non-detergent oil, and if there is a sightglass, fill to half-way up that glass. Otherwise, try mastertool repair or need a manual websites.
Posted on Nov 26, 2009
erpaalai
  • 999 Answers
SOURCE: need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Posted on Dec 30, 2009
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
I need an instruction manual for husky air compressor model no. Wl651003aj
Go to the Campbell Hausfeld website at http://www.chpower.com/ and under 'Service and Support' click on 'Manuals/Parts List'. Put your model number, WL6510, in the search box and you'll be presented with all the parts breakdowns and manuals for that series compressor. The first part of the serial number on your compressor is a date stamp so use that to determine which manual or parts list you need.
Feb 26, 2012 | Air Tools & Compressors
Compressor will not auto start and when manually started it will not load it just keeps cycling the solinoid. its a ssr up6 30 60hz
First of I really need some more info. Model and serial # on tag on compressor.Does this up6 have a controller on it. First of all the unit will not load unless it has enough air pressure to open the inlet valve. Is the unit in modulation. If so you need to switch it to on/off line then start. if in modulation and the system/tank is empty there is no air pressure to operate the modulation feature. I would start by switching it to on/ off line first. After started and air in system you can switch to modulation and the unit will operate fine as long as there is air in the tank/ system.
Jun 22, 2011 | Ingersoll Rand Air Tools & Compressors
I have an ingresoll rand air compressor model # 242-5D, it has two motors and for some reason one does shut off when it hits the right amount of pressur at 150psi the second continues to run until the...
Does it have separate compressors on tank?. You probably need to adjust cut in and cut out pressure switch. I have seen several air delivery systems that utilize 2 separate compressors, this allowed a backup if the one online failed. The units had unloader valves and the compressor never stops running. A call for air pressure would close unloader valves and unit would pump up and the the valves would unload.
Jul 28, 2017 | Ingersoll Rand - Rand Type - 30...
Hard starting does this model have an unloader
There are two types of unloaders used on IR compressors. One is oil pressure controlled, and second is manually activated for starting. According to the photo and model number provided, yours is manually operated. Follow air line from compressor to tank. The pilot valve (brass valve) between airline and tank is a multi-function component. There is a flip leaver or pull ring w/ hold that unloads the compressor by venting air thru small muffler. The valve also contains the check-valve holding pressure in the tank, a means of adjusting pressure and controlls throttle for engine. For easy start, flip leaver upright and start; to run, flip leaver to right angle of stem.
Nov 19, 2010 | Ingersoll Rand 2475F13GH Ir Stationary...
30 gal compressor - trips the breaker when I turn it on Model 919165130 Serial 2016180483
Try draining the air out of the tank,all of it.Now turn on the compressor,if it will come on,and build up to the cut off point,then the check valve/pressure release valve is bad,replace it.
Aug 29, 2009 | Air Tools & Compressors
Need owners manual for devilbiss pro 4000 air compressor
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Jun 19, 2009 | Air Tools & Compressors
Need a user's manual for a Clarke Pioneer Model AC2002A air compressor.
hi try Machine mart manchester uk hope this helps merlin v12
Jun 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
56 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
