Error Code 6 ymgi indoor mini split - Heating & Cooling
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 400 Answers
SOURCE: GE mini-Split Error code
Replace the indoor pc board and thermistor.
Posted on Mar 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
heatman101
  • 43501 Answers
SOURCE: Brand new LG mini split,24,000 BTU. One indoor
That is a typical indication of a low charge of freon....
Check the charge and also for a leak in the system...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Error Code E3. I can run 3 of the 5 air handlers 24/7 without problem, when I turn them all on it gives the error code after about 24 house, any idea on why this is?
most likely the utility transformer was inadequately sized. call the utility company, they might have to upgrade (resize) the transformer to serve the demand of the housing complex.
Oct 11, 2015 | YMGI 60000 Btu Dual Zone Mini Split Heat...
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
What is a code c1 on a samsung mini split?
Error code = C1 or CH1
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
