Question about Nania Dreamer LX
Manual How to separate seat
Is there a separate fuse for the passenger and Driver side accessories such as the seat warmer and the mirrors? Drivers side works, passenger side does not.
Depends on which model car you are talking about, some do most don't. The mirrors and seat warmers are more likely to be on separate fuses.
Dec 29, 2014 | Seat Cars & Trucks
Is the connector there on the harness under the seat for power options even if i have manual seats?
There is a good chance of it, manufacturers figured out that it can be cheaper to make one part for all models and options, if there is a separate fuse for seats you might need to add it to the fuse box to power that part of the harness up, but there is a good chance that if you have an extra connector under the drivers seat that you are good to go.
Aug 03, 2014 | 2001 Ford Taurus
Combi instruction
It depends on your car seat. Follow your instruction manual for your child seat and your car. Not all seating positions have tether anchors.
"Rear-facing only" seats do not tether (these have a separate base and carrier)
"Rear-facing convertible" seats may tether.
"Forward-facing" seats usually tether (some MUST tether).
Jul 19, 2014 | Eddie Bauer Baby Gear
How do I life the rear seat to fold down the back of the seat?
will need to try and see if latch is damaged or debris is jammed in latch with the other side up look under at latch also check the cable --you can try kneeling on seat and bounce and pull on tab to try and get it to release
Jun 13, 2017 | 2004 Hyundai Santa Fe
I have a 2002 Oldsmobile Bravada...Yesterday all of a sudden my passenger's side window stop working(up and down)...the power lock and the heated seat all stop working on my passenger's side...?
If you have an Owners manual, try looking for a fuse panel diagram. Your could have a bad connection inside the doorpanel which shorted the fuse. The seat drive motor must be wired to a separate circuit coming from the floorboard and its okay.
The circuits are wired independently to protect the lighter wires from the heavy drain of the seat motor. If you had the heated seat function working on the seat at the same time as adjusting the seat motor it would be too much for a single circuit, so they gave you two circuits.
If you are going to work on the door panel, disconnct the NEG battery cable so you won't short out something taking it apart.
Another Repair place you might try is a Glass Replacement shop. They install the inner workings of window tracks daily and remove the door panels to do it. They would be able to find your wires, test your window motor, and get you on your way quickly.
Unlike a Dealership, they have a high turnover of glass installations daily. Some even come to your house to repair your problem. Your car would be repaired more quickly with these services.
Nov 22, 2011 | 2002 Oldsmobile Bravada
Want to remove all clothes on evenflo car seat, model# 5581356, manufactured in may 11 2005. Couldnt get manual for it
  • Hi, I can help.
  • When you get to the page, in the middle of the page, scroll down to #8 (stroller) and #9 for the car seat "port about."
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Evenflo Baby Gear
Heated seat does not work on drivers side. Fuse checks ok
the grid in your seat has shorted out if the right one works The relay controls both seats so you diffently have a burnt grid
Feb 14, 2010 | 2003 Buick LeSabre
Driver's seat belt sticking - 2003 Mazda Protege
Not really, you just need to be carefull not to brake the plastic covers but you can get them separate than use a thin spanner and you should be able to do it without removing the seat.
Nov 15, 2009 | 2002 Mazda Protege
Jeep Grand Cherokee passenger power seat quit working
no problem...That's what it's all about...small victories every day...
Good luck with your jeep!!!
Apr 19, 2009 | 2000 Jeep Grand Cherokee
Nania Dreamer LX Logo
Top Nania Baby Gear Experts
Nikki  Mclean
Nikki Mclean
Tom Chichester
Are you a Nania Baby Gear Expert? Answer questions, earn points and help others
