Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Monitor goes black
Hp monitor goes black
  • 1 more comment
  • Dick Stubblebine Dec 07, 2007
    been told that the printed circuit card inside the unit has "cold solder" connections. I have had it apart & can not find any "outstanding" areas requiring the solder?
  • jc6317 Apr 17, 2008
    monitor goes black
  • ichey103 Apr 28, 2008
    theare no brown/yellow/red transformers with a ferrite core in mine
    Champion:
  • 220 Answers
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Posted on Apr 08, 2008
Hp monitor going black
It sounds like the monintor, borrow another one from another machine and see if that solves the problem. If so it is a bad monitor, if not it is mostly a bad vidio section in the computer or the video card if it has one.
Aug 08, 2014 | HP Pavilion 23bw Black 23" LED Monitor...
Maintaining functioning of Hp f2105 monitor
I would suspect the monitors internal power supply has issues. If you are capable of soldering and know some electronics replacing bad capacitors is doable at home. Try joining badcaps.net and posting your monitor problems there as that is how I found the info I needed to repair my HP W2207 monitor.
Apr 21, 2013 | HP Pavilion Computers & Internet
My 2207 monitor goes black after saying "monitor
Usually means you need to update your video driver. What model is your computer you are connecting the monitor to?
Mar 03, 2011 | HP Televison & Video
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor goes to black. i power off and on and
Your problems describe a bad Power Inverter. It's a small circuit bard inside the monitor, it powers the CCFL lamp of your monitor. Could be cheap to replace, but in most cases you just buy a new one. It could also be a bad CCFL lamp.
Mar 14, 2010 | HP Compaq FP 7317 17" Flat Panel LCD...
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
207 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
