Question about Garden
Craftsman lt1000 tractor will not start. believe that fire is not getting to starter
  • 49 Answers
SOURCE: Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Posted on Jan 29, 2009
SOURCE: Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
Craftsman lt1000 manual
check starter solenoid
Jun 12, 2013 | Garden
Engine smokes and smells like electrical when trying to start craftsman lt1000 mower
Smoke can be a sign of 2 possibilities and one being oil the other being that you flooded it... as for the electrical smell is it coming from the starter from tryin to start it for to long. Careful you could burn up your starter thats never good just give some time between trying and keepthe trying short very short
Oct 03, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman LT1000 Tractor. It has a
if you have a model # 917.272672, you can download a free user manual at
http://www.craftsmanlawn.com/Tractors-Riding-Lawnmowers/917.272673/
Oct 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
try replacing the relay in the middle of the ignition and starter.
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Good battery & good starter but won't crank craftsman lt1000
check and see if the white wire on the starter solenoid has voltage when the key is in the start position. If so, the solenoid is bad. If not, back probe wire until you find voltage.
Feb 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
