Question about Garden
My gravely zt 2352 mower will not start
The key will not turn it over at all but if you jump it on the solenoid it will turn over but acts like it isnt getting any fire
woobie dog
  • 1273 Answers
SOURCE: Riding mower won't start from key switch
Do you have power to the switch? This is the only thing that jumps out at me, as you already did the right things.
Check that. I bet it'll get you going!
Regards, --W/D-- Feel free to rate my answer.
Posted on Jul 24, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
smartr10U
  • 1305 Answers
SOURCE: Mower won't start. Makes clicking noise.
Check the battery terminal connections for cleanliness and that they are free of corrosion. If the contact is corroded, this is what the clicking would be from.
The battery could be charged, but if the connection is dirty, the power won't be able to engage the solenoid properly.
Hope this helps.
Posted on Jul 24, 2010
  • 760 Answers
SOURCE: Battery isnt getting charged by
40b7c2b.jpgTry to always list the model number. Something like 917289472 would be the model number. Here is a wiring diagram for that model. Note the test voltages with unit running. Check the wiring from the regulator to the ignition switch and from the switch to the battery. It is possible for the ignition switch to be bad and keep it from charging. Test at these terminals with voltage tester. You should have more than 12 V at the regulator( diagram says 9-16 volts). If you need the manual you can go to www.searspartsdirect.com and download diagram. Enter YOUR model number. Good luck!
Posted on Oct 20, 2010
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
Gravely zt 48hd starts, blades engage and start, but mower will not move forward or reverse after lowering brake. suggestions?
There should be a lever/engagement clutch on the back of the mower. It is disengaged when you manually push it. It will have to be engaged again to allow it to move.
Jun 24, 2016 | Garden
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
2009 zt bad boy wont start unless you jump solenoid which is new starter is rebuilt relay replaced . Ignition switch new replaced . wont turn on with key - jump solenoid fires up runs then pops the 25...
if you are blowing fuses then you have something shorted out or connected wrong. before you spend more money throwing parts at it get a wiring diagram and ensure the wires are good and connected right
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 28, 2013 | Garden
How much oil is needed to fill the engine?
Start with a qt. check dip stick an add acordinly szm230
Apr 15, 2011 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
How to change the clutch on a gravely ZTR 260z. What keeps the clutch from spinning around on the engine shaft? A diagram of the clutch assembly would help. Instruction on removing and reinstalling might...
There is an "anchor" that bolts to the chassis, and it has a rod-like part that sticks up to engage a notch in the PTO clutch to keep it from spinning. Look here -- there are parts diagrams for your mower (find the right model number) that will help a lot. Good luck!
Jul 07, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
