Question about Water Heaters
Worcester bosch rd532i manuel
Fault code EA. i went straight for electrodes and cleaned them as they were very scaled. still did not help. i have checked that the condensate isnt backing up. im a gas registered engineer but the client doesnt have the manual. can you give me any pointers before i go for the gas valve. as it definately is trying its hardest to light before it goes to its fault code.
zeusfaber
  • 247 Answers
SOURCE: i have a worcester greenstart
Not the best day for this to happen.
Check the system pressure and top up if necessary - but after that the best advice is to get the people who fitted it for you to come out and sort it - These Worcester combis usually have a 5 year parts warranty and with a boiler that's just a few weeks old, you oughyt to be able to get the labour for nothing as well. It would be a shame to throw those benefits away by tinkering yourself.
A.
Posted on Jan 01, 2009
  • 234 Answers
SOURCE: Error Code EA - not in owner's manual
Think maybe just loose connect to me.
Posted on Mar 14, 2009
  • 659 Answers
SOURCE: lost manual
I couldn't find your model number but here is the website where you will be able to find it if they have it available online. You can also find contact info as well.
http://www.worcester-bosch.co.uk/homeowner/literature/product-guides-and-brochures
Posted on Apr 01, 2009
SOURCE: I have a Bosch AquaStar 2400ES-NG, Error Code EA
There are three electrodes (connected next to each other by a single piece of metal) that run up into the heat exchanger. They are situated behind the black plastic air intake in the lower half of the unit. Pull out the electrodes and clean them off with steel wool or fine sand paper. Also take the opportunity to blow the dust out of the inside of the unit and clean out the air intake.
Posted on Jun 15, 2009
  • 1015 Answers
SOURCE: Bosch SX 250 tankless water heater will attempt to
This is also known as a flame rectification sensor. It basically is what the computer board uses to detect if the pilot flame is lit. When it makes an attempt to fire is there any evidence of flame ignition? This error does not mean that the sensor is bad for sure. The error could be caused because the water heater is only making three attempts to fire and then shutting down. These water heaters are very complex and have many sensors,valves, ect that are all controlled by a computer board. Some of the basic things to check for are... Make sure that you have plenty of gas pressure. These units have a built-in pressure switch and will have issues if they are starved of gas. Most of these tankless water heaters are up to 400,000 btus and a half inch gas line or undersized connector won't work well. You can also check and make sure there is no pipe dope are debris stuck in the screen inside the gas line where it enters unit. Inspect the pilot assembly for debris or obstructions and try to blow out with compressed air. Also look for any loose electrical connectors on the board or to the sensors...one may have come loose.
Posted on Sep 07, 2009
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
THERE IS NOT IGNITION. IT SPARKES BUT WONT LIGHT.
sounds like your not getting gas...maybe a vapor lock,,,,,,,make sure you are compressing the pilot button all the way.....try to listen and see if you hear gas flowing....
Jan 19, 2013 | Bosch Worcester Spark Electrode...
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
Model Aquastar 250 is not running and is showing an error code of EA. What can be the problem?
  1. Verify that all manual gas shut off valves are open.
  2. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air from gas line (especially on new installations). Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  5. Verify gas pressure meets specifications outlined in chapter 3.8. See Bulletin TWH-G2-03.
  6. Verify venting meets specifications outlined in chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  7. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If not, Call Bosch Water Heating with observations. Readings from above gas pressure test will be req
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
Feb 03, 2011 | Bosch Water Heaters
My worcester bosch 28 si 11 series is fireing up on heating and systematicaly every couple of seconds turning the flame down to half flame then turning back up to full flame and the spark electrodes are...
This could well be a fan relay fault on the pcb, as in if the fan is cutting in and out it's triggering the pressure switch which in turn is sending confusing signals to the ignition and gas valve. Have you removed the controls connector cover and observed the righthand of the two little white boxes in the middle of the control board (pcb) with the boiler switched on? (be careful because it's live i.e DO NOT TOUCH ANYTHING) Is it sparking?
Nov 18, 2010 | Bosch Water Heaters
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
My hot water heater is not producing hot water. Flashing code EA
hi i think your problem is with a dirty connection on one of the three electrodes they are situated under the black plastic air intake in the bottom half of the unit take them out and clean the connections with fine sandpaper hope this helps
Dec 03, 2009 | Bosch & Tankless LP Hot Water Heater
I have a Bosch AquaStar 2400ES-NG, Error Code EA appears, I hear ignitor clicking, heater tries to activate 3 times then EA code reappears.
Apr 20, 2009 | Bosch AquaStar 2400ES-NG
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
