Carrier 38th030300 ton
Condenser fan motor
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: Carrier A/C unit blowing hot air and fan not spinning
check the belt drive and refrigerant
Posted on Jul 12, 2009
  • 252 Answers
SOURCE: Carrier AC condenser unit stopped working. Power
if all is as you say you probably have a bad "dual motor run capacitor"
Posted on Sep 07, 2009
  • 7 Answers
SOURCE: the condenser fan for carrier xarios 300 is not
there is a run capacitor is probably bad.
you can purchase a replacement one from slakey brothers. However the capacitor will still have a charge after the power and wires are removed. after turning off the breaker use a long bladed screw driver and ground the electrical leads to discharge the capacitor before removing. take it with you to the supply house along with the model and serial number of the condensing unit.
Posted on Apr 15, 2010
  • 146 Answers
SOURCE: Goodman 3 ton heat pump - condenser fan motor gets
did you get a motor with the same amps? did you check to what the amp draw is on the old motor to the new? reason is different amp ratings on motors need dfferent blade pitches, also 2,3 or 4 blades pull different cfm. is the motor a belly band mount or does it hang by studs? also check to see if the capacitor is the correct uF. hope this helps you feel free to ask any question if this does not help you.
Posted on Jun 09, 2010
My carrier condenser fan has stopped running.can i just pour water over the coil and use the condenser untile the repairman gets here on friday
Messy - why not just hook up a regular fan and hook it up to the power line that ordinarily powers the condenser fan.and have it do the blowing until the repair person comes out on Friday. The ideal fan is one of those old floor fans that used to blow air in a 360 direction.
Jul 02, 2015 | Carrier 3 Ton Infinity Puron A/c outside...
What kind of capacitor do i need for 3 ton carrier ac unit
Where is the capacitor connected? To the compressor, inside fan or condenser fan motor. The value of the capacitor is stamped into the metal housing of the capacitor.There will be a number followed by the letters mfd
Aug 28, 2014 | Carrier Heating & Cooling
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
Need the motor size on a carrier 38SQ940311
Carriers usually have a 1/4 HP condenser fan motor.
Jul 19, 2012 | Carrier Heating & Cooling
Squeaky condenser fan motor on Carrier 3 ton central air. I oiled once 4 months ago and noise stopped but noise returned today. Is there a special oil for the berings?
Hello
Usually a light oil.Wd 40.
Most of these motors are sealed bearings,meaning they do not get oiled.When they start making noise it means the motor bearings are getting worn and the motor will need to be replaced soon.
I have got 5 to 6 months out of noisy motors using a light household oil or WD 40.
Sep 22, 2011 | Heating & Cooling
How to connect a fan motor for a 7 ton carrier ac unit
7 ton, sounds like a commercial unit, if this so could be three faze. is this fan for cooling the outside condensor coils or the blower motor for moving air through the inside duct work
Feb 02, 2011 | Heating & Cooling
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
A/c unit not cooling
if it is making strange noises during operation it is going out on high pressure due to the condenser fan not running , check the capacitor for the fan to make sure it has not expanded also check if motor is getting proper voltage , is capacitor is good and motor has proper voltage supplied then you have a bad motor and should be replaced with new capacitor.
Phil
Jun 11, 2009 | Heating & Cooling
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
