Question about Vacuums
Eureka powerline limited edtion model number 4352
How to take bottom cover off to change belt?
reddevil6
  • 1673 Answers
SOURCE: How do you remove the vacuum roller off
I assume this an Eureka? If it is then there are 2 screws on the top cover, take them out and the cover will come off, the belt and brush roller are out in the open now. Brush roll Part #54941-1 and belt part #54312.
Posted on Feb 16, 2008
  • 10 Answers
SOURCE: Need to replace belt on
No, do not remove the torx head screws for a belt change. If there are any screws that need to be removed for the belt change, they will be phillips head. What is model # of vac??
Posted on Oct 24, 2008
SOURCE: Eureka model 4335 - belt removal (top cover)
loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
  • 3 Answers
SOURCE: HOW DO i CHANGE THE BELT ON MY EUREKa powerline
turn the vaccum upside down and unscrew the screws in the bottom, pop that cover off and you should be able to remove the wheel assymblie. take the old belt out,slide knew one over the shaft and replace the cover and screws
Posted on Mar 25, 2010
carmin77
  • 113 Answers
SOURCE: How to change the belt
The belt is directly connected to the brush roller. Remove the brush roller cover. Pull out the brush roller. Remove all carpet strings. Change the belt.
Posted on Jun 11, 2011
How to change the belt on a Eureka powerline limited edition vacuum cleaner.
Jun 11, 2011 | Vacuums
Mar 25, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Need to replace belt on Eureka Powerline 12.0 vac. Screws look like Torx head or something on bottom of vac. Are those the screws that need to come out for changing? If so, what size do I need?
Oct 04, 2008 | Eureka Vacuums
Belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
Jun 22, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Need to get access to the belt on my Eureka model 4475
Eureka Model #4475
need to get access to the belt on my Eureka model 4475
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There may be 2 different ways to get to the belt, I checked the Eureka website and I believe you have to remove the bottom plate and the brushroll and belt are exposed and you would hook the belt on the brushroll 1st and then use a screwdriver with a bent hook and then you can pull the belt onto the pulley, once the belt is on the pulley then you can track the belt by rolling it on the brushroll & belt pulley --- the other way is that there are 2 screws on the bottom of the of the vacuum – remove the screws and then the top cover should lift off the vacuum to expose the belt – then follow the same procedure ads listed above. Check with you local vacuum dealer in your area in the yellow pages or use the Eureka website or customer service phone number listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Apr 16, 2008 | Vacuums
Changeing belt
On the top nozzle, there will usually is 2 screws holding the top done. There are slots or holes on each side near the front and the screws or in these holes. Remove them, remove the top cover and then you can get to the brush roll and belt.
Dec 22, 2007 | Eureka 2991AVZ Bagless Upright Cyclonic...
Eureka whirlwind light speed
Wish you had given your model number, but most of these, there are 2 screws on the top cover, near the front, remove those and the top comes off, the belt and brush roll are exposed.
Dec 02, 2007 | Vacuums
Nov 12, 2007 | Vacuums
Vacuums Logo
66 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
