Question about Invicta Mens 0477 Corduba Swiss Chronograph Black Polyurethane and Stainless Steel Watch
Need a part... "PIN" for the strap link on my invicta 0477 watch
I have AN Invicta 0477 Corduba swiss chronograph, The Pin On That hold bracelet came off and i lost pin i need a new pin in order to fix original bracelet... PS Where can I buy "PIN"...? Need pin for strap link.
shaggyrat
  • 1224 Answers
SOURCE: Resizing my watch
screw
small jeweler tools
take to jeweler for 5 bucks they will knock a link or 2 out for you
Posted on Jun 12, 2008
SOURCE: invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Posted on Jun 16, 2008
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
escapement
  • 2334 Answers
SOURCE: i have an invicta corduba diver watch how do i
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
escapement
  • 2334 Answers
SOURCE: tried to remove links from invicta model #6716
Get fine needle and move the hollow tube back and forth till it matches the links. Then you will be able to separate links. Rate me plz.
Posted on Mar 05, 2010
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
I have a Invicta 4504 and I cannot get it started. Please help
It'so possible that the new battery is defective. Are you sure the stem/winder is fully seated?
Dec 18, 2014 | Invicta Corduba Collection Retrograde...
Invicta watch instructions
Straps are usually held in place by two spring loaded metal pins between the two lugs on either side of the strap. Look at the ends near the lugs you should be able to see them, use a very small flate blade srewdriver to pull back on the pin and once you get it, it will pop out of the hole its in.
Aug 18, 2014 | Invicta 15997 Mens Venom Chronograph Blue...
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do i get links out of invicta Corduba Swiss Chrono?? do they screw out??
Apr 03, 2011 | Invicta Watches
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do I remove pins to size an Invicta Sea Spider model #0140
mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Jul 03, 2010 | Invicta Sea Spider Chronograph...
How do you remove the links from an invicta subaqua venom stainless bracelet?
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Jun 10, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
I have an invicta corduba diver watch how do i remove some links
Jan 09, 2010 | Invicta Watches
Invicta Mens 0477 Corduba Swiss Chronograph Black Polyurethane and Stainless Steel Watch Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
