Question about Pool & Spa
Emerson 1081 pool motor
Hello - I have an Emerson 1081, Model K63 CXERE 4772, HP 3/4, Pool Pump. I believe it is being used as the booster pump for a Letro Legend Pool Cleaner. The pump connects to a large round head by 5 or 6 screws, sorry, I don't know what that head is called. Near the bottom of the head there is a round hole which had a white plastic screw in it. Is was leaking water, and I reached down to tighten it. It blew out and a stream of water begin to shoot out. I turned the pump off, and you could hear it sucking in air. My best guess is that it is some kind of drain plug. Do you have the replacement part for this?
3 Suggested Answers
ozepool
  • 21 Answers
SOURCE: LETRO POOL CLEANER WITH BOOSTER PUMP NOT SUCKING MUCH.
Is it a jetvac? you said the bag does not stand up, I'm sure it is a pressure cleaner, the pump maybe no good or your pool pump is not providing anough water for the pressure pump. Check every thing, hair and lint pot on pool pump should be full, clean filter. bob@ozepool.com
Posted on May 24, 2010
jharwell668
  • 640 Answers
SOURCE: I have a Pentair letro legend platinum pool
You DO need a booster pump to power these automatic pool cleaners. It will not work without one.
Posted on May 11, 2011
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 manual
What Emerson model, serial and or catalogue number do you have? 1081 is the basic and generic code indicating that it meets the standards for a pool motor, that's all.
Oct 16, 2013 | Emerson Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
I need to replace the bearings on a 1.5 HP Emerson 1081 Pool ump, Model number K62CXESE4792. Can I get the bearings from you?
YOU WILL NEED 1 OR TWO 6203 2RS AND MAYBE A 6204 2RS, THIS MOTOR CAN USE 2 SIZES OF BEARINGS. YOU CAN GET THEM FROM YOUR LOCAL AUTO PARTS STORE $$ .. OR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, IF YOU ARE LOCAL ? LONGWOOD FLORIDA. I'D GIVE THEM TO YA FOR FREE , NO CHARGE !
Jun 06, 2011 | Emerson Pool & Spa
I have emerson 1081 (model # K63CXETN-4820) pool motor. I am looking for impeller for this motor. Can you plz point me to where can I get the impeller?
that motor will fit all sorts of pumps, YOU NEED TO KNOW WHAT KIND OF PUMP you have,, hayward,jacuzzi.. the motor pictured is a round flange.. look on ebay to see if you can find that looks just like yours ! than ask the question..
May 12, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I had a Smith 1HP pool pump with a square flange on my Haywwod sand filter. After 12 years it died. The pool shop sent me home with a Emerson 1hp., 1081 pool motor. It doesn't pull the water like the...
Sounds like there is an impeller problem. A 1hp emerson should be fine. Take it apart and recheck impeller and diffuser. I am assuming they gave you a new seal to replace with the motor.
Apr 26, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Where can i order the impeller (center dish cover) for a emerson 1081 3/4 hp pump
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Feb 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I have an Emerson 1081 Pool Pump Motor , every time I turn it on it trips the circuit breaker , is the motor bad ?
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
Oct 19, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
