Question about One For All URC-7555 Remote Control
Bush led24970dvdfhd tv 7 dvd & player
Tv screen flashes different colours
ORthe modelo.
https://www.youtube.com/watch?v=ohYYX27T_no
Jan 14, 2017 | Bush Televison & Video
Bush led24970dvdfhd no power no lights nothing
The main power supply regulator section circuit should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 22, 2013 | Televison & Video
My Bush 24" TV is only showing a white screen !
Check the video output voltage to CRT board. It might be absend.
Apr 26, 2012 | Bush Televison & Video
I have a Bush 7"
Hi Philip, mine doing same as yours. Any help please
Aug 07, 2011 | Bush Televison & Video
In laymans terms ! got a bush 1080p tv, but when
1080P resolution is only avalable with BD players, Upconverting DVD players,Some media players and some satellite PPV movies.
Nov 18, 2009 | Bush Televison & Video
Bush PDVD0707 personal dvd player will not play
Oct 03, 2009 | Bush Televison & Video
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Manual for bush dfta5a not supplied at purchase.
I have the Bush DFTA1A set top box and plugged the aerial into the back of it, then connected the 3 cables red,white & yellow also into the back of it and the other end of those cables into my DVD/TV. then follow onscreen prompts to install it. works fine.
Aug 25, 2009 | Bush DVD2038 DVD Player
Why is my bush tv black and white when i watch a dvd
you are using the svhs scart if it has another scart swap the plug over
Dec 08, 2008 | Televison & Video
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
One For All URC-7555 Remote Control Logo
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
