Question about Dehumidifiers
I have a frigidaire dehumidifier model lad254ntl that water will not run out of hose and the bucket fills up and shuts off.
I hooked up the hose to the fitting and tightened and ran hose over into drain but no water comes out of hose but the bucket will fill up and shut off when full. what can i do to get the water to come out of hose instead of filling bucket? `
  • 308 Answers
SOURCE: I have a drain hose hooked to the dehumidifier,
The bucket should not fill up. Did you remember to take/knock the plug out of the drain hole?
Posted on Aug 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Dehumidifier won't drain
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
  • 4736 Answers
SOURCE: My frigidaire dehumidifier mod. #LAD254NTL
Dave, this happens quite frequently. It''s due to a clog in the hose or a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie, slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Posted on Jun 27, 2011
  • 4736 Answers
SOURCE: My model is Frig. Dehumidifier,
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Posted on Jul 10, 2011
al_kupchella
  • 843 Answers
SOURCE: Whirlpool AD50USS Dehumidifier WILL NOT DRAIN THROUGH HOSE
I have a similar model. There are two drains, one for the hose and one directly into the bucket. The hose one is supposed to be lower, but I had to put a 3/8 inch block under the right side of the unit to get the water to favor the hose instead of the bucket. Another possibility is that the far end of the hose is higher than the near end. If you can't lower it, you can put the whole dehumidifier up on blocks. One other thing to check is that the hose has a rubber washer in it where it connects to the unit. Use a tissue to see if this connection is dry. If it leaks, it will just drip into the bucket.
Posted on Jun 05, 2012
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
My model is Frig. Dehumidifier, 70 pint. model # LAD704DUL. I hooked up the hose for continuous operation, but the bucket fills up too, even though water is definitely coming out of the hose. It...
Jul 10, 2011 | Frigidaire Dehumidifiers
My frigidaire dehumidifier mod. #LAD254NTL only fills the bucket and will not transfer to the connected hose
water to follow.
Jun 27, 2011 | Dehumidifiers
Have model FDL70S1 that is hooked up to a hose into a drain. For some reason now it is collecting in the bucket and shutting off once the bucket is full instead of going down the hose. Any ideas to help?
It is possible that your hose has a build up of algea in it that has started to jell. The water you are removing from the air is very pure and allows this growth. I would remove the hose and clean by blowing through it or hooking it up to faucet and flush it out. If you can get it open then running a cup of bleach thru it on a regular basis will stop this from happening again.
May 30, 2011 | Frigidaire Dehumidifiers
Water fills in the bucket and will not drain
I've got the same problem. It drained through the hose for 6 months, but recently stopped and now fills the bucket. I connected a new hose, but that didn't help. I found some debris inside the dehumidifier (where you connect a hose to), but removing that didn't help. I may try taking the unit apart to see if somehow a cricket or some sludge got built up inside.
I'll post my findings. Hopefully it won't be too complex or nasty!!
Oct 06, 2010 | Frigidaire FDF50S Dehumidifier
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
It runs but doesn't collect water. Had the hose
try adding heat to the room it needs heat to draw out moisture and close any doors or windows to help isolate the area desired. just obvious tips to try if not already done so
Mar 22, 2010 | Frigidaire Dehumidifiers
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Figidaire 25 pint dehumidifier
Check the point on the tank (Bucket) where the hose connects to. Make sure there is no obstruction at the outlet of the bucket to the hose connection. Next make sure the hose has no kinks or no loops that may trap air to the drain. If necessary for a long run to the place of drainage raise the dehumidifier to a higher level for better drainage.
Jun 20, 2008 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
78 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
