Question about Wanlida Group LTD-1510 15 in. TV/DVD Combo
Pc connection doesnt work with computer
Hooked up computer to monitor, switched to "PC" mode and post screen shows along with windows xp logo screen. However, it doesnt enter windows main screen, instead monitor reports on screen "out of range". What does this mean? I tried computer on another larger flat screen tv and it works, along with 2 other computers which it seemed to work with. Could it be because VGA card is somewhat weak. Computer model is HP Pavilion 7940. I am also using 6ft high density vga cable. Does it need a driver or something? Ed
    Sniper:
  • 140 Answers
The TV you are hooking it to is not able to show the resolution you have the computer set to. Start by setting your computer resolution to 800 x 600. If that works than try 1024 x 768. If you go too high you will get that "out of range" message. The instruction book that came with your TV has a listing of the available resolutions the TV will show.
Posted on Aug 30, 2007
You were right, However resolution wasnt the problem. Set refresh on winXP to lowest setting ,60 hertz. It was previously set to 85 hertz. Now it works at any resolution. I thought that flat panels dont require refresh rates at all. Thanks.
SOURCE:
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
I am trying to connect my PC to my TV,. Both have VGA connections. My PC is hp pavilion a1020n. I just connected the cable, switched to PC mode in my TV, and start the computer. At first it shows the...
You probably have a mismatch between the two devices relative to resolution. Check both to make sure that you are not asking the TV to do something that your normal monitor can accommodate. The Windows logo is normally drawn in the default VGA resolution of 640X480 or 600X800.
If you are using the common computer monitor resolution of 1024X768 your TV may not be able to sync to this.
Mar 14, 2010 | HP Computers & Internet
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Windows XP in Power Save Mode and no buttons get it out
This can be solved in either of two steps.
>There should be "SPECIAL KEY" in the keyboard labelled as "SLEEP" or "STANDBY"...try clicking it..
<or>
>Check the monitor ON-BOARD settings for "POWER SAVER MODE".
Hope this will solve u r problem..
Plz revert back for any queries.
May 27, 2009 | Microsoft Windows XP Home Edition
Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Feb 07, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
New 19" flat screen monitor only shows analog on the screen
finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
May 12, 2008 | Gateway FPD2275W LCD Monitor
Wanlida Group LTD-1510 15 in. TV/DVD Combo Logo
183 people viewed this question
Top Wanlida Group Televison & Video Experts
Ekse
Are you a Wanlida Group Televison and Video Expert? Answer questions, earn points and help others
