Question about Boating
Charging stator wiring diagram /1981 .25 hp johnson ng
Where do the wires go when fitting a charging stator on a 25 hp Johnson 1981 model
    Sergeant:
  • 352 Answers
SELOC REPAIR MANUAL WWW.OVERTONS.COM OR WWW. WESTMARINE.COM
Posted on Jul 26, 2013
5 Suggested Answers
  • 77 Answers
SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Posted on Jun 23, 2009
  • 95 Answers
SOURCE: 1964 johnson 9.5 hp outboard runs but no reverse.
Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..
Posted on Aug 11, 2009
  • 53 Answers
SOURCE: need to change impellor on 1988 70 hp johnson how
first go to www.crowleymarine.com to get a picture breakdown of your water pump. website instruction, click on part catalog tab, click on omc Johnson and evinrude tab. choose product line, year tab, engine size, choose model. click on gearcase. the picture showes all parts you have and the correct order they go. ok now we are ready to disasemble the lower gearcase from the motor.(1) trim the outboard down using the tim and tilt system (2) shift remote control into forward gear, this lines up the shift rod so you can reach it. a picture of the linkage is refernce number 50 on the picture from crowleymarine.(3) Remove engine coul, under the carburators you will be able to see the shift rod. if you can't see it follow the shift cable to the shift linkage to the shift rod(4) the shift rod has a hole in the top, that a long screw goes through, connecting shift rod to shift linkage. remove this screw(refer to picture downloaded)(5) again refer to the downloaded picture remove these bolts that i list. number 66 there is 4. #77 there is 1. pull off #76 trim tab.#68 there is 1. #70 there is 1. lower unit will drop after you remove all bolts. remove the impeller housing. look at impeller you will see the fins are bent in one direction. put new impeller in with fins bent in the same direction. reinstall housing and gear case following my dirction in reverse order.
Posted on Nov 02, 2009
  • 53 Answers
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
Posted on Nov 04, 2009
How to check to see if rectifier is charging. The part number is585195 .it is a 1996 90 hp Johnson model number j90toleda
rectifiers do not charge ,
their purpose id to change ac current to dc current to run the electrical circuits connected to the battery
it is the voltage regulator that controls the charge from the stator of the motor
using a multimeter set on volts dc
connect across the battery and read the voltage ( 12--13.2 volts ) start the motor and increase the rpms to around 2000 rpm and read the meter
it should be 14.5- 14.8 volts dc
that indicates that the system is charging
if not , take it to a service center that has a marine electrician to fix the problem
Jul 03, 2017 | Johnson Boating
Wiring diagram for this boat?
some electricians use a multimeter to ohm out (or verify continuity) and then they figure out what goes here, but the colors are also sometimes a clue and lastly, you need to give a specific make and model boat.
I found older wiring here:
http://retrocrestliner.com/phpBB3/viewtopic.php?f=2&t=1353
https://www.google.com/imgres?imgurl=http%3A%2F%2Feastblu.info%2Fcache%2F4%2FBingimages_57126.png&imgrefurl=http%3A%2F%2Feastblu.info%2Fboats%2Fboat-wiring-diagram.html&docid=g0RJETx8yo09pM&tbnid=m9uYB0Xoo-Xk0M%3A&w=864&h=674&bih=1044&biw=1920&ved=0ahUKEwjF7bzVgvbMAhWCxYMKHfMGDOcQMwgeKAIwAg&iact=mrc&uact=8uploadswith imagewiring-diagram-boat-z5ayflqiktoj1cqxqeolfqsg-3-2.png
and a forum where som eoe may have it to post for yu:'
http://forums.iboats.com/forum/engine-repair-and-maintenance/johnson-evinrude-outboards/112163-1960-40hp-johnson-seahorse-wiring
May 25, 2016 | Cars & Trucks
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
I need the wiring diagram for a 1957 johnson seahorse
You have got to be kidding. There is hardly any wiring on a 1957 Johnson. If it is not electric start look at a 1972 6 hp, same wiring.
Jun 24, 2015 | Boating
Johnson trim tilt problems
WWW.OVERTONS.COM ORDER A SELOC SHOP MANUAL
Jul 23, 2013 | Boating
Wiring diagram for 30hp Johnson Mod.AJ30ELCUB
For Evinrude service manuals or Evinrude Johnson owners manuals for 1996 models and prior, please contact the Ken Cook Company at (414) 466-6060 (414) 466-6060.
Jan 18, 2010 | Boating
Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Jun 18, 2009 | Boating
I need wiring diagram fer a older 110 hp johnson.
1967 100 hp johnson ob - starter wont turn over - maybe safety switch or solenoid ? need wiring diagram
Apr 24, 2009 | Johnson Boating
Boating Logo
184 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
