Question about Garden
Need a diagram for pto cable on a toro riding mower modle # 13al60rg044
What does it connect to on mower deck
  • 148 Answers
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Posted on May 19, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 78 Answers
SOURCE: HONDA 3011 LAWNMOWER RIDING HOW DOES THE BELT ON
I dont have the diagram but remember the V of the belt aways goes in V pulleys and the back of the belt on flat pulleys . Honda provides you with diagrams at hondapowereqipment .com
Posted on Oct 27, 2009
centxfarmer
  • 4 Answers
SOURCE: WE ARE IN NEED OF A DIAGRAM THAT SHOWS HOW THE
page 44 Figure 71
Posted on Apr 20, 2010
  • 221 Answers
SOURCE: I need to find a free diagram on how to route a
Try this link. I think it will help you out.
http://manuals.deere.com/cceomview/OMM142698_I0/Output/OMM142698_I011.html#40242
Posted on Jun 29, 2010
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 | Toro Garden
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
