Question about Gaggia Classic Brushed Stainless Steel Espresso Machine
Gaggia espresso machine won't percolate
Everything turns on, and the steamer works. However no water comes through to the cup; it doesn't percolate coffee.
  • Anonymous Mar 16, 2014
    water comes out of steamer when just doing espresso
  • Anonymous Mar 24, 2014
    i place espresso ground coffee in the holder and lock it.
    i press the on button and then the espresso button down
    when lights are on.
    the espresso comes out and squirts all over the place, and then eventually fills my cup
    there is a litle of water in the coffee holder when i detach it
    Problem Solver:
  • 8 Answers
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Posted on Dec 30, 2007
How do I operate this Gaggia Fantastico II Espresso machine?
Sep 06, 2012 | Coffee Makers & Espresso Machines
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
Gaggia Evolution Filtering Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jan 03, 2009 | Gaggia Evolution Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Pump problem on a Gaggia Espresso Evolution
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Jul 09, 2008 | Gaggia Evolution Espresso Machine
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Classic Brushed Stainless Steel Espresso Machine Logo
498 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
