Question about Linksys WRT120N Router
QoS Settings not Saving
I put in my MAC address for my computer, but when I press save settings, all of my previously entered devices (including the new one) dissappear from the list and don't save.
  • 196 Answers
SOURCE: Setting Up QoS (Quality of Service) Settings on the WRT54G
What is QoS? QoS is a popular feature that ?guarantees? better service to selected traffic on a network. The goal in configuring QoS is to give priority and attention to certain devices or services so that they can use the maximum available throughput and speed available on a certain network when it is needed. Accessing the Router?s Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Enabling and Configuring QoS 1. Once in the Router?s Setup page, click on the Applications and Gaming tab. 2. Next, click o n the QoS sub-tab. 3. Select the Enable option to turn on QoS features. NOTE: If you do not see the QoS sub-tab, you must upgrade your router?s firmware to the latest version. See Answer ID 1508 for more information. The WRT54G offers three (3) different types of Quality of Service (QoS) options: MAC Address-based, Application-based, and Port-based. Choose the appropriate type for your needs. · MAC Address-based QoS: In the Device Priority section, you can specify the hardware MAC address of the computer or device that you wish to give priority to. You can assign a Low or High priority for up to two (2) specific MAC addresses found on your local network. · Port-based QoS: In the Ethernet Port Priority section, you can control bandwidth according to which of the physical LAN ports your computer or device is plugged into. You can assign a Low or High priority to computers or devices connected to any of the router?s LAN ports (1 through 4). NOTE: You can also Enable or Disable ?Flow Control? for each LAN port, which is a technique that controls the speed at which data is received. If Flow Control is enabled for a certain port, then a receiving device is not overwhelmed with data as it is coming in. You can even control the flow further by specifying the Incoming Rate Limit to a certain speed. · Application-based QoS: In the Application Priority section, you can control bandwidth with respect to a specific application being used on the network. You can assign a Low or High priority to a particular application or service. There are several pre-configured Web services that use well-known ports, like FTP and HTTP, which you can use. You can also customize up to three different applications by entering an Application Name and the Specific Port # that the software application uses. If you are unsure of the port number that is used for a particular application, contact the software manufacturer for more information. 4. When you have finished configuring QoS settings, click on Save Settings button to save your changes.
Posted on Feb 16, 2006
ethan859
  • 19 Answers
SOURCE: unable to write network settings to device
Which network settings are you trying to write? In general, try getting Network Magic. It's a free download and trial and can help with some Linksys/Cisco problems.
Also, you may try getting into the firmware itself. Use any web browser and enter the following IP address as your URL: 192.168.1.1. At that point you're directly accessing the settings on the router and should be able to make any changes you need. By the way, this only works if you're connected directly to the router via Ethernet cable.
Posted on Nov 08, 2009
  • 387 Answers
SOURCE: Have had router for years, works great but need to
Type in your web browser address bar 192.168.1.1.
Posted on Feb 22, 2011
  • 4 Answers
SOURCE: after typing the settings in
your telephone link is down
Posted on May 07, 2011
kevinangell
  • 81 Answers
SOURCE: How do I find the site where I can add the ip
You need to check the gateway address of your router and that will be the address of your router setup page. To get the gateway address, Go to start> run> type cmd > On the blinking cursor, type "ipconfig". Look for the gateway address. Open your internet explorer enter the address of your gateway, press enter . You will see a prompt asking you for a username and password.leave the username box empty and enter the password you setup for your router when you initially install it.
Posted on Aug 22, 2011
How to disable MAC filtering
MAC (Multimedia Access Control) addresses are unique sets of codes assigned to electronic devices that identify the devices on a network. MAC filters work by either allowing or denying only specific MAC addresses. MAC filters are a great security measure; however, if your network needs to be open to public or guests, or you're adding and removing devices often, then you should consider turning off MAC filtering.
EditMethod One of Three:
Wireless Routers (Windows)
  1. 1 Open the Command Prompt. You can access it from the Start menu, or by pressing ? Win+R and typing cmd.
  2. 2 Type .ipconfig and press? Enter.
  3. 3 Find your active network connection.There may be several connections listed in the readout, and you may have to scroll up to find your active connection.
  4. 4 Look for the .Default Gatewayentry. This is the address for your router. Write it down.
  5. 5 Open a web browser. You can access your router's configuration page from any web browser as long as your computer is connected to the network.
  6. 6 Enter the .Default Gateway address into the browser's address bar.
  7. 7 Log in with your admin account.Routers are protected with an admin login and password. Check your router's documentation or look up the model online to find the default login information.
    • If you can't figure out how to log in to your router, you can reset it by pressing and holding the Reset button on the back for about 30 seconds. After the router restarts, you will be able to log in with the default admin information.
    • Most default logins use "admin" as the username, and then "admin", "password", or a blank field as the password.
  8. 8 Open the "Advanced" section and look for "MAC Filtering", "Access Control", or something similar. Actually defining where the "MAC Filtering" section is located is very difficult, as the location and labeling is different for every router. Generally, you can find the "MAC Filtering" or "Access Control" settings in the "Advanced" section, though it may also be found in the "Security" or "Wireless Settings" sections.
    • Not all routers use MAC address filtering. Some router's limit access based on static IP addresses assigned to each device.
  9. 9 Disable MAC filtering. Again, the wording and location will vary depending on the router, but you will generally be able to select a "Disable" option to turn off MAC filtering.
    • This may be a checkbox, a button or a selection that you can make.
  10. 10 Save your changes. Click the "Apply" or "Save" button to save your changes to the router settings. Your router will apply the changes, which may take a few moments.
    • If you are configuring your router over a wireless connection, you may be logged out when settings changes are saved.
Jun 08, 2014 | Belkin F5D7234-4 Router
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
I'm trying to connect my router I need the ip address and password please
Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below.
    Accessing the router settings through a web browser.
  4. On this screen you should change the Router Name from its default value to something unique so that your Base Station will not be confused with another. Scroll to the bottom of the page and click Save Settings then click Continue when the Settings are successful dialog is displayed.
  5. Next, click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings and then Continue when the Settings are successful dialog is displayed.
  6. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  7. Next click on the Wireless MAC Filter subsection at the top of the page. Then Enable the Wireless MAC Filter option and select the option to Permit only PCs listed to access the wireless network. Click on the Save Settings button at the bottom of the Filter List window and then Continue.
  8. Now click on the Edit MAC Filter List button to pop up a new window (shown below) where you will enter the MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed. You may now close the Mac Address Filter List window.
    Creating a MAC Address Filter List will prevent unauthorized computers from using your connection.
  9. Finally click on the Administration tab at the top of the page. Change the default password for accessing your wireless router setup pages by typing a new one into the Router Password field and then confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed.
  10. If you encountered any problems during this configuration procedure, please consult the manual that was included with your router or contact the manufacturer.
  11. Your Linksys Wireless Router is now secure.
Sep 21, 2011 | Linksys Wireless-G WRT54G Router
I cant sign in on ps3 to play on internet keeps saying the code number 80130182 what can i do tryed a lot. of things but no working
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the router. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1 Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe
May 30, 2011 | Video Game Consoles & Games
I get this error 80130182 when trying to sign in
Its down to a Router issue on your network
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I have full signal from the router, then when i connect my laptop to it i loose all signal and has to keep reconnecting
I would suggest you to reconfigure the router after you reset it. please make sure that you do not use a wireless phone nearby the router which is a major cause of the disconnection.
First disconnect the RJ 45 wire connected to your desktop Ethernet card coming from the router and connect this wire to the 'Internet' port on the
router now there is a connection to the 'Internet' port of your Linksys router.
Next use the RJ45 wire, which came in the Linksys box & connect one end to the Ethernet card of your laptop and the other end to any of the ports numbered 1 to 4.
Connect the power adapter pin in the power socket Power up the Linksys router & Laptop computer. Now lets get to the basic configuration of the Linksys wireless router.
This is how its have done successfully.
Open IE6/IE7 browser and type 192.168.1.1, a window will pop up & ask for username & password. Default user name is blank & default password is 'admin' after which you will come to the screen
'Internet Connection Type' is by default 'Automatic configuration DHCP' leave it as it is J (I did not which caused me a lot of grief J )
In 'Router Name' enter a name of your choice.
Let MTU be 'Auto'.
At 'Local IP Address' enter 10.10.0.1
'Subnet Mask' 255.255.255.0
'DHCP' is 'enable'
'Starting IP address' leave it as it is, this will be changed later.
'Static DNS 1' 192.168.1.1
'Static DNS 2' 203.94.227.70
'Time Zone' change it to relevant location.
Click on the 'Save' button.
At this point you will loose contact with the wireless router thru the browser. Double click on the computer icon in your task bar & go to the 'Support' tab and see the IP taken automatically by the machine most probably 10.10.0.2. Now type 10.10.0.1 in the browser location bar to gain access on the config page of the router & change (see above) the 'Starting IP address' to 10.10.0.2. click on 'Save'
Next click on the 'Wireless' tab give a name to your network also called SSID, remember all wireless machines on this network should have the same SSID ie network name & select what wireless network mode you need. If you have only laptops, which operate in the, 802.11g mode, (most new machines) then select 'G Only'. Click on 'Save Settings'.
You can now turn to your wireless PC or laptop to connect it to the wireless network. Here I am assuming your laptop has a built in WiFi card, if you are using an adaptor then follow the instructions of the adaptor maker. XP has a very user-friendly wireless networking utility. If you're setting up a network for the first time, use the Windows Wireless Network Setup Wizard, in the Control Panel. This copies configuration info to a USB flash drive that you can insert into each additional PC or device. If you use Vista (like me) it's just as easy going thru the Control Panel for first time users. After you have gone thru the setup wizard and it has recognized the network with the name you had previously given it, now you should be able to access the Internet.
Leave the laptop on for the time being and lets focus our attention on the router configuration thru the browser of the desktop.
Click on the 'Wireless tab & then on 'Wireless MAC filter' (on how to find the MAC address of your wireless machine go to right to the bottom of this page)
Click on the 'Enable button' and on the 'Permit button' & click on the 'Edit MAC filter list' and add the MAC address also called 'Physical address'
Click on 'Save Settings' in both windows.
Next click on the 'Wireless' tab -> 'Wireless Security' tab and select the appropriate settings (AES, TKIP or AES+TKIP) depending on what your laptop supports. Remember that WPA2 is considered the best as also AES+TKIP if your laptop supports it go for it. Select the same settings and password on your laptop. Click on 'Save Settings'
In the 'Security tab' select 1, 2 & 4 check boxes.(See below). Click on 'Save Settings'
At the 'Administration' tab -> Management change the routers password.
Also select the check box 'HTTPS'. Click on 'Save Settings'
After you have made all the relevant then go to the 'Administration' tab - 'Config Management' and take a back up of your settings. This can be done at a later stage too when you have made all the changes you need.
PS Remember that now to access the router thru the browser the address is 10.10.0.1 and NOT the one you will find in the user guides (192.168.1.1). And to access the D-Link 502T thru browser you type 192.168.1.1. Happy surfing.
you see below is the DNS settings
Finding the MAC Address and IP Address for Your Ethernet Adapter
Windows 2000 or XP
1. Click Start and Run. In the Open field, enter cmd. Press the Enter key or click the OK button.
2. At the command prompt, enter ipconfig /all. Then press the Enter key.
3. Write down the Physical Address as shown on your computer screen. It is the MAC address for your Ethernet adapter. This appears as a series of numbers and letters.
The MAC address/Physical Address is what you will use for MAC address cloning or MAC filtering. Note: The MAC address is also called the Physical Address.
Windows Vista
1. Click Start -> Accessories -> Command prompt
Nov 16, 2010 | Linksys Wireless-G WRT54G Router
How can i configure the wireless access point?
Oct 10, 2010 | Linksys Wireless-G WRT54G Router
Will not connect to the internet wireless. keeps saying error 8001000b
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
3. Locate a tab for FILTERS
4. Select MAC filters.
6. Save entry. At this point router will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Or find someone or hire someone who could fix that for you..
May 28, 2010 | Sony Playstation 3 (PS3) Console
8001000b error
It is also important to go through the connection settings to make sure everything is correct:
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Hope this helps!
Apr 05, 2009 | Sony Playstation 3 (PS3) Console
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys WRT120N Router Logo
128 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
