Question about Huffy Men Mountain Bike (26")
How do I replace the rear wheel derailer and what tools are needed?
HOW CAN I STOP MY REAR WHEEL RUBBING AGAINST THE FRONT DERAILER SET
Either the wheel is not centered in the frame, It's the wrong diameter/width wheel, or the derailleur is crooked (or did you mean the chainwheels/sprockets?). Need clear picture or find in-person help - knowledgeable friend, bike co-op or bike shop.
Mar 21, 2016 | Marin Belvedere Commuter Road Bike
Is there a way to safely dismantle the rear gear shifter?
Remove the rear wheel and see if the shifter (derailer) is able to move all the way up to first gear. If it is then you have a stretched cable. If not then a bent derailer. Most likely a stretched cable.
Jun 22, 2015 | Cycling
Ezip
Since you didn't specify which derailleur needed adjusting, I have included links to adjusting both the front and rear derailleurs.
Park Tool Co ParkTool Blog Front Derailleur Adjustments
Park Tool Co ParkTool Blog Rear Derailler Adjustments derailleur
Apr 13, 2014 | Cycling
I have a Kawasaki kx20s 10 speed boys mountain bike that needs the rear brake cable replaced and both the front and rear derailer gear cables adjusted or possibly replaced. Is there a manual or diagram of...
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Aug 26, 2011 | kawasaki KX20 Boy's BMX Bike
Just bought a used mountain bike...chain keeps falling off
1) Replace the chain.
2) Adjust the travel of the front and rear derailer.
3) Make sure the rear wheel is set properly in the rear fork.
May 07, 2011 | Bike Extreme Lite Youth Shoulder Pad
How do i stop chain going over first gear
There are two screws on the rear derailer that are used to limit the travel of the derailer. (That is, they limit how far the derailer moves in an out.) Have someone move the lever while you watch the derailer move back and forth. You can usually see which screws these are. If you can't tell, them put the derailer in a middle gear, turn one of the screws to the right about a quarter turn and try it out. If it no longer goes into high gear, that was the wrong screw. Turn it back and try the other one. By the way, do your testing by just holding the wheel off of the ground and turning the pedals by hand. This is best done with two people. Good luck.
Nov 19, 2010 | Cycling
Hufyy 26" Tundra 18 speed bike....GEars are clicking
Sounds like the rear derailer needs adjustment. Are you handy with tools? There should be a micro adjuster on the cable for the rear derailer. It might be located at the shifter on the handle bars, or at the rear derailur. Follow the cable from shifter to derailer, Look for an adjusting nut, when you find it, turn it counter clockwise to remove slack from the line. Go one turn at a time, ride it and shift through the gears. Repeat until the noise stops or you run out of adjustment. If that doesn't fix it, you need to srew the adjuster all the way back in, shift it to the highest gear, loosen the bolt the holds the cable on the derailer and pull the cable tight and tighten the bolt back down. If you are unsure about doing this, go to your local bike shop and have them fix it AND show you how to do it.
Aug 12, 2010 | Cycling
I have a 2007 Specialized s works roubaix. I have a ''clicking sound under load only that ''seems'' to be coming from the crank because it clicks at every rotation of the crank. the bike has about 3500...
I can tell you by my own experience that the click at every rotation is because the bearings on the BB, I had the same in my bicycle and after install a new crankset and BB it went away. I installed a Shimano Deore Hollowtech II and it works nicely and no noise.
May 18, 2010 | Specialized Bicycle Components Specialized...
How to put back the derailer after exchaned the rear wheel pls?
Check out this walk-through on wheel removal and replcaement on Park Tool's website:
http://www.parktool.com/repair/readhowto.asp?id=160
i hope this helps
-matthew
Oct 28, 2009 | Cycling
Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
May 30, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Huffy Men  Mountain Bike (26") Logo
27 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
