Question about Car Audio & Video
Clarion nz501e I'm looking for the app and the MCU software
I got a clarion nx 602, I install it everthing works eccept the navigation system. Say failed to start at first time.
I have the same issue. Started a few weeks ago by locking up the unit while using the nav. Then the nav app will not load at all. Any luck on getting a resolution?
Dec 16, 2012 | Clarion NX602 6.2in DOUBLE-DIN NAVIGATIO
F6E2 error code
Drive Motor Tachometer Error (Unable to Detect Motor Speed) - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in. Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Nov 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error F28
The F28 code is a comm failure between the MCU and the CCU. First, check the wiring harnes connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
Yes, I read a couple past members that diagnosed it as the MCU being the cause more than the CCU.
So you can order the MCU and/or the CCU, then I'd install the MCU first to see if that fixes it.
Oct 14, 2012 | Whirlpool WFW8300SW
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do u turn on your webcam
Its activated through webcam software. It shows up as a usb device usually or has the specific name for that model cam.
Most HP's come with a basic version of CyberLink Youcam application.
If you no longer have the software, take your model and serial number down, go to HP's website and look for the software under your model. Make sure you correctly select which OS you're running from HP's drivers and apps pages.
Worse comes to worse, you would buy cyberlink's software (or upgrade).
Jul 28, 2012 | HP Pavilion dv6000z Notebook
How to shut off F10 alarm on Frigidaire Gallery oven?
follow the next steps and proceed with commong sense: God bless you
  • 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears.
  • 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
  • Jul 27, 2012 | Frigidaire FGGS3045KF Stainless Steel Gas...
    I need an owners user manual for Clarion model ARX6670z
    You can try pacparts.com to see if you can get an owners manual there. They are an authorized clarion parts dealer.
    May 30, 2012 | Clarion ARX6670Z Cassette Player
    WhoCalled iphone app no longer works and is unavailable from iTunes, help!
    it's very possible that apple has decided it's no longer allowed in the iTunes app store.
    They maintain control of all the apps that are published in the app store and have the right to remove any they see fit to.
    It's very possible that the older version of the "WhoCalled" app will not work with the latest iOS. Also what happens sometimes is they will change the name of the application and re-publish it. There are a number of things that could have happened....I would look to see if they have made updates to the app that could have changed the name or if the company that made it was purchased and a new iteration of the app is available. If not I'm sure there are plenty of apps in the app store that do this.
    May 16, 2012 | iPhone Apps
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
