IBM 9068-A03 printer error 31 - Office Equipment & Supplies
5 Suggested Answers
SOURCE: Have 2 IBM 9068-A01 Dot Matrix Passbook Printer.
The cover is not shut all the way or the magnet is not making the connection between the cover and the chassis. A1 is a microcode checksum error. don't know what that means.
Posted on Mar 03, 2011
  • 11 Answers
SOURCE: I have a IBM 9068
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Posted on Aug 31, 2011
  • 11 Answers
SOURCE: IBM 9068-A01 printer loads paper crooked
Make sure it looks like this before installing. The gears have a habit of falling out of place while installing.
http://www.youtube.com/watch?v=b3u295hA06M
Posted on Sep 01, 2011
1861bohdan
  • 3 Answers
SOURCE: IBM 9068-A03 microcode update fail.
Use the oldest computer you can fine with Windows98 or event 95
Posted on Mar 26, 2012
How to reset passbook printer ibm 9068
When you turn on the power, the microcode version and then the release level of the microcode are presented on the LED display, and the device runs the basic assurance test and then resets the hardware.
If you need configuration changes done such as how the printer communicates and such, then you need to know all the functions and codes for configuration changes.
The self-test runs only in the self-test state. To place the printer in this state and start the self test:
1. Make sure the printer is turned off.
2. Press and hold either Start 1 or Start 2 on the operator panel; then turn on the printer. Keep holding the button at least until "00" is displayed on the LED.
Note: The left 0 blinks, and the right 0 stays on.
3. When 00 appears on the LED, the self-test "00" is ready to run. Insert an 8.5x11 Letter sized piece of paper into printer.
4. Press Start 2 to run the self-test "00". This will print the Configuration of your printer.
Feb 28, 2013 | IBM 9068 A01 Passbook Business Printer...
Mar 15, 2012 | Computers & Internet
IBM 9068-A03 printer error 22
error 22 normally caused by the motor shutter not functioning.check the motor connection and test the motor movement.if the motor is moving,try to adjust the motor position.it might help if the motor still working or else,replace the motor.
Jan 12, 2012 | IBM Office Equipment & Supplies
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
c. Main Card -
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
Have 2 IBM 9068-A01 Dot Matrix Passbook Printer. Both are showing Errors. There is no paper-jam and I have installed 4 different Ribbons, still no joy. First Error code is 0F and the second Error code is...
Oct 28, 2010 | IBM Network Printer 17 Laser
I need olivetti pr2e printer driver free
www.argecy.com/index.php?pfile=9068-A01.html
Aug 03, 2010 | IBM Office Equipment & Supplies
Error 31 with new toner
please clean printer fuser or clean thermostator
May 15, 2009 | Lexmark E352dn Laser Printer
Mar 27, 2009 | IBM Office Equipment & Supplies
495 people viewed this question
k24674
jasbo
jasbo
