Question about Dehumidifiers
Sears dehumidifier 53550 - Dehumidifiers
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
The dehumidifier when it is turned on is tripping a breaker off. If this needs a repair, where does one go to get it repaired. It was purchased in June 2008. It has a 5 year warranty on some of the parts...
Cathy, since i a Kenmore ( a house brand for Sears). Sears in Home Service is the place to call.
Since some parts are still under warranty, the repair may cost you nothing. But, you must have your Proof of Purchase for the warranty to be in affect. Either way, Sears is the place to call.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Kenmore 54351 Dehumidifier
Have a kenmore dehumidifier 42-54501 - I bought it w/o instruction book. Can you tell me where to get instruction book??? Thank You
Since it's a Kenmore ( a Sears house brand) that was made by Whirlpool. You can download the Owner's Manual at Sears Parts Direct or Sears Parts Central.
Hope this helped you, Joe.
Jun 05, 2011 | Kenmore 54501 Dehumidifier
Fan blew apart.....need a new one.
You can purchase them directly online from Fedders or from Sears Parts Central. Fedders makes dehumidifiers for Sears under the name Kenmore.
Apr 25, 2011 | Fedders A7DH45B2A Dehumidifier
Do I need an attachment to connect hose to my new dehumidifier?
it should be generic. you just need a part with the same thread pattern. you could fix that a lot of different ways. as long as it screws in your ok. make sure you put some teflon tape on it to prevent it from dripping
Oct 06, 2009 | Kenmore 54501 Dehumidifier
I have a Kenmore 54701 dehumidfier, less than 2 year old. the power is on, a fan seems to be running, I no longer hear a compressor turn and, and no water is collected?
The sealed system of the Kenmore 54701 dehumidifier is warranted (Parts & Labor) by Sears for five (5) years. Since the fan in your unit runs but the compressor doesn't, I suggest that you return it to Sears and request (demand) a new replacement unit under their warranty. I say "demand" because Sears will undoubtedly tell you that the problem is due to some "other" component which is not covered, and will charge you mega-bucks to repair it. Been there - - done that.
FYI, read the (very low) customer reviews of these units on Sears website and you'll see you're not alone in your experience with Sears' inferior quality units.
Above all, do NOT pay to have it repaired. That money is better spent on the purchase of a far more reliable brand of dehumidifier - - (which will most likely cost less that what you paid for the Sears unit).
Mar 09, 2009 | Kenmore 54701 Dehumidifier
Power OFF button doesn't work; unit keeps running, overflows, and doesn't stop
I have the same problem! The "pcb" referred to in the previous reply is undoubtedly what Sears refers to as the "COVER ASSEMBLY, DISPLAY", part number 3551A20109B. It is possible, but highly unlikely, that the defective part is the ESCUTCHEON, p/n 3831A20079D. Sears lists the cost of the COVER ASSEMBLY, DISPLAY as $17.25 plus, undoubtedly shipping and tax. The part seems to be available only from the Sear Web Site under "PArts Direct". This dehumidifier is a piece of garbage. I previously had to replace the SENSOR ASSEMBLY, p/n 6877A30013L. This item turns off the unit when the water tank is full. This dehumidifier has my room flooded - twice - when the unit failed to turn off and overflowed.
While under waranty Sears/Kenmore attempted to repair the unit five times. They never succeeded and when the warranty ran out they would not repair the unit unless I paid for it. Thats when I started doing my own repairs!
Oct 01, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
73 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
