Question about Linksys SD208 8-Port Ethernet Switch (SD208KIT)
Lights flash all lights flash, no connectivity
Why does the data light keep flashing when device is on and it won't connect to pc
Are you using the correct cable to connect?
Has the camera ever connected to your computer correctly? If not, it may be that your computer isn't recognising the camera.
Try removing the card from the camera. If your computer has an inbuilt card reader, try using that. Or get a usb card reader.
Feb 17, 2016 | Cameras
Constant flashing blue light
The flashing blue light means the Bluetooth is connectedconnected, device is on.
Jan 31, 2014 | Hmdx Hx-p240gy Jam Plus Portable Speaker,...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Hi. Theres a flashing light on my adp4601. its the start light.i've taken off cover and checked for loose connections but it all seems to be fine. i've checked filters and pipe connections. could you shed...
The light flashing indicates that you have a fault on the appliance ...count the flashes it will flash say 3 times then have a little break then flash 3 times again and it will continue to do this until the fault is resolved...message me witht the amount of flashes and i will tell you waht the problem is. You could have 1 to 13 flashes or a continues flash.
Speak later
Nov 11, 2010 | Whirlpool Dishwashers
Red light flashes as i plug in the adapter
solid red light means ready to connect. If you hve a flashing red light that means you have a hardware ploblem. Try using adiffent USB. go to xbox 360 suport for more imfo.
Jan 29, 2009 | Microsoft Wireless Network Adapter Xbox...
Flashing dsl light
The DSL light flashing on the modem is natural for it means the device is synchronizing. But if the DSL light continues to flash, you have to wait a while before connecting, it shouldn't take more than a minute. If it does, you may need to contact your service provider because that is uncommon whether there is active Internet connection or none.
Sep 17, 2008 | 2wire (1000-000057-000) Modem
Connection dropping
If the lights are flashing - that's OK. Wireless light will flash because the connections and beacon transmission, port lights will flash because of local connections. We can troubleshoot this for a while but I think this might be a problem with the box. Probably the best option is to replace it. In case you would like to play, try to run Ethereal and capture the packets and analyse them.
Jun 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Beginner with Studio Lights
will need more information, but the basic idea is to connect the trigger on top of your camera's hotshoe, and then connect the receiver to the flash.
Feb 11, 2008 | Cameras
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Linksys SD208 8-Port Ethernet Switch (SD208KIT) Logo
26 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
