Question about Microwave Ovens
Whirlpool microwave model#MH1160XSB-4 fuse location
How do I know if the fuse is bad or not after I figure out where to locate the fuse or how to get to it?
  • 150 Answers
SOURCE: location of fuse
behind the control panel remove the grill and the screw at the top center of the control board. give it a bit of a lift and pull out you can then access the fuse if I remember correctly it should be to the left in there somewhere
Posted on Apr 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Fuse location on wall mounted Whirlpool MH7140XFQ
The fuse is in a holder located behind the control panel assembly.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, you can download it here.
If the oven is dead, it may also be a bad magnetron thermostat or oven cavity thermostat.
The first one can probably be accessed through the opening behind the control panel, but the oven cavity thermostat cam only be accessed by removing the oven from the wall, then removing the outer cover.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 23, 2008
SOURCE: Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Posted on Mar 17, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: trying to change a fuse on microwave.
It may be the fuse or the thermal cutout / thermostat associated with the magnetron.
You say you have the service manual? If you mean the folded-up "mini-manual" that should show the relative locations of the parts in a perspective view.
Also, you can find exploded views at the Sears parts site.
Looking at the "interior parts ii" exploded view here, it shows the fuse (drawing reference # 5001) on the small RF noise filter board located on top of the air duct assembly.
You'll need to remove the oven from the wall to get to it for testing & replacement.
The installation instructions are handy to pull the oven from the wall.
If you've misplaced yours, the Sears site may have them free.
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on May 30, 2010
SOURCE: Fuse location on a KitchenAid Microwave
my kitchenaid microwave oven does not heat anymore
everything else works but it will not warm anything up
Posted on Aug 06, 2011
WHERE IS THE FUSE ON THOSE MODELS NN-SD277 MICROWAVE
If mounted on the wall above the range, this may be a 2-man job to remove, and the electrical repair may not be for DIYer. 1st ask "Why is fuse bad?" Usually the fuse is located with other electrical/electronic components behind the control panel. To access: unplug, remove MW from wall, remove bonnet (3-sided metal shroud), expose the electrical compartment on the right side, search for the fuse (usually 1 1/4 x 1/4D cylinder). Replacing the fuse may not be the final answer.
Nov 28, 2014 | Microwave Ovens
Microwave model number mh1160xsb. It will only turn on for 15 seconds at a time what could be wrong with it
There is a thermal fuse that sometimes becomes defective or the magnetron is getting to hot causing a shut down, exhaust fan may not be running which cools the magnetron, should be checked.
Mar 05, 2012 | Whirlpool Microwave Ovens
Have a whirlpool microwave model GH5184XPS-4. This morning I turned the "Cooktop Light" on and a few minutes later I heard a small pop, looked over and the lights had gone out. One of the bulbs...
yup most probably that is the case.
you can locate the fuse usually it is placed near the main power supply or just trace the supply cord going in your unit. but before you open your unit be sure it is unplug to avoid electric shock.
slowly disassemble the unit and be sure that you can replace all the screws back to it original positions. after locating the fuse, check if it has a continuity and be sure to replace the same fuse rating. also investigate why the fuse had blown up and look for abnormalities.
if nothing found then replace the fuse and put all back then test the unit. if still it blows fuse, their must be something wrong with the unit and have it service to qualified personnel.
Dec 31, 2010 | Whirlpool Microwave Ovens
We had a power surge and now the microwave does not work, model number MH1160XSB-0 whirlpool, what could be the problem? We put a fuse in and it kept blowing.
Model MX6110XB. Nothing worked. LCD panel was dead. Unplugged and replugged; and everything works.
This fix described for the GE Spacemaker. They say problem result of a power surge. Apparently applies to different manufacturers; or does GE make Whirlpools?
Dec 09, 2010 | Whirlpool Microwave Ovens
No power. All house breakers reset. Possible fuse but don't know where it is located. model WMH1162XVB-2
The M/W fuse is located inside the oven and accessed by removing the cover. They are usually just past where the power cord enters the oven from the rear.
Jun 20, 2010 | Whirlpool MH1160XSS Stainless Steel 950...
Whirlpool mh1160xsb over range that buzzes when cooking
It depends on if it is just a loose component that needs tightened up or if it has started failing. it will require some investigation and trial and error to resolve. I have had some success in resolving vibrations and some were real challenges. It is a matter of isolating the noise maker and seeing what can be done.
Eric
Oct 04, 2009 | Microwave Ovens
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
