Question about Car Audio & Video
Farenheit double din dvd won't play the cd or DVD
hogan doan
  • 227 Answers
SOURCE: alpine dvd stereo double din
Your laser eye might be dirty or tired(out of alignment). Buy a cleaning kit, if it does not help try have someone who knows how to re-align it.
Posted on Mar 06, 2008
SOURCE: How do I get audio on my farenheit dvd-15?
Did you try tuning in to FM 88.7, this should pick up dvd audio
Posted on Jul 11, 2008
j_del
  • 1586 Answers
SOURCE: jensen double din dvd monitor uv8020
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Posted on Sep 13, 2008
SOURCE: kenwood ddx6019
can i hook up a ipod to my head nit
Posted on Dec 04, 2008
SOURCE: ALPINE CVA 1003 AND A DHA 5680 DVD/CD CHANGER
you have the amp remote wire hooked to the power antenna lead instead of the amp wire on the deck otherwise just hook it to a switched +12 volt source. You sure you got a DVD changer instead of just a cd changer
Posted on Apr 11, 2009
I have a 07 tahoe with a double din player the cd player load/play cds but the dvd player will not even operate to load the dvd is there anything i can check
There is nothing that you can do except pull the player out and send it in for repair at a GM approved repair station.
Feb 16, 2017 | Televison & Video
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
How do i get my double din kenwood to play music videos?
Do you get video display with a store bought DVD? Have you hooked up the parking brake wire?
Sep 14, 2014 | Kenwood DDX370 Double-DIN In-Dash DVD/CD...
How to change the dvd region code on Pioneer AVH-X2600BT - Double Din CD/DVD Car Stereo with 6.1"
This is not an adjustable device. You cannot change regions. It is manufactured for one location only.
Aug 10, 2014 | Pioneer Car Audio & Video
Hi ive got an 12VCITY MA-7004 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i
hi, i bought <a href="http://www.12vcity.com/wholesale-car-electronics-car-dvd-2-din-car-dvd/13-car-double-din-dvd-player-buy-car-double-din-dvd-player-ma-dvd7004.html">12VCITY MA-7004</a> on 12VCITY official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.I think maybe you have connect the wrong wire and have bum out the built in amp.
Jan 11, 2012 | Car Audio & Video
Kenwood ddx6019
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
May 25, 2008 | Kenwood DDX-6019 Car DVD Player
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
