Question about Coffee Makers & Espresso Machines
Bianchi sprint E3s
Choose product without coffee
I have a eddardo bianchi sport sx bike serial number ds529448 what can you tell me about this bike
Nobody is likely able to tell you more than you would find with a Google search for "edoardo bianchi sport sx," but it's nothing special.
Oct 15, 2017 | Bianchi Cycling
Please date my Bianchi bicycle, serial # is 083204
Unforunately, there is no database of Bianchi serial numbers
Nov 18, 2014 | Bianchi Cycling
Bike serial numbers 323623
Contact your local bianchi bike dealer
Aug 24, 2014 | Bianchi Cycling
I have a Bianchi Strada hybrid. I want to raise the handle bars. What size stem riser should I get? Is this the right way to do this?
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Sep 23, 2011 | Bianchi Strada
I have a 1995 Bianchi Super Ibex with Zoke front shock/fork. It seems to be locked, or frozen. I'm not familiar with the item. Any guidance or advice?
The best thing to do is take into your local bike shop so that they can both look at the Fork and determine "why" it is having this problem and so they can show you how to maintain the fork properly as well as any other tips they can provide, such as setting up for you weight, riding style and terrain.
There are a number of possibilities as too why your fork is not moving, and without seeing it or a better description this is best advice I can offer, anything else is simply guessing. I believe that the Zoke front end was a Marzocchi fork, They are very good about listing all their owners manuals however that one seems to be missing. On a 16 year old fork, most likely it needs to be overhauled (minimum), or replaced.
Mar 29, 2011 | Bianchi Ibex
Is there a Bianchi bike owners manual so I know how to adjust the gear lever?
Look on the brake lever for a manufacturer and model number (probably Shimano). Even if you can't establish a model number, go to the website and find the mountain bike shifter that is closest to yours, There will probably be a technical manual for it and it will describe how to install and adjust it. You'll also want to look for and understand the derailleur it controls.
http://techdocs.shimano.com/techdocs/index.jsp
Dec 26, 2010 | Bianchi Mountain Bike 19"/49cm
Owner's manual for a 2008 bianchi cortina
I would contact your local Bianchi Dealer and have them order you a Owner's Manual. They can get one through their Distributor. You can find your local Dealer at this link http://www.bianchiusa.com/dealer-search/
Jun 10, 2010 | Cycling
Trying to find contact info on warrenty issues for bianchi
Bianchi doesn't do warranty(?) work through a main factory, so you'll have to contact a dealer near you. Use their dealer locator and enter your address to find the closest one.
Jun 10, 2009 | Bianchi Cycling
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
