Question about Garden
John deere X155R. Keeps blocking the grass in chute. Lawn short and only slightly damp, non stop blocking.Any solutions ??
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
SOURCE: chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Posted on May 01, 2010
The blades don't push the grass to the bags
the blades are the wrong ones for throwing grass clippings
they have to have turned up edge to generate an air flow out of the chute to the bag
talk with the mower shop for the correct blades
Sep 09, 2017 | John Deere Garden
John Deere LA140 wiring diagram
Request the wiring diagram directly from John Deere.
Jul 28, 2016 | John Deere Garden
My L110 John deere lawnmower won't pick up grass
hi lift blades Google Search It take a hi lift blade to do a good job of vacuuming/ bagging . If you have them make sure they are not upside down.
Mar 18, 2016 | John Deere L100 Series
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Our John Deere 110 is killing our grass in short stripes that look like equal signs
sounds like a fuel leak from the tank to the caburetor. Your mower has a fuel pump that pumps the fuel from the tank to the carburetor and when you are running the mower the fuel is leaking out the fuel line onto the grass. Check the fuel lines for cracks or splitting and replace it with fuel line from a lawn mower shop.
Jul 06, 2012 | John Deere Garden
Mtd bagger not bagging ...its 100 deg today grass is short and the tube keeps clogging up w /grass it wont go into the bagger .how can i fix the problem??? chris
The MTD web site has a list of items to check:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=68&p_created=1027017166&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=214&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YmFnZ2VyIGNsb2dz&p_li=&p_topview=1
Aug 10, 2009 | Gaiam Reel Lawn Mower Grass Catcher
Chute for bagger keeps getting clogged
Apr 22, 2009 | Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
