Question about Hyundai Heating & Cooling
Syncing universal remote to air conditioner
Having trouble syncing a generic general electric universal remote to a window unit hyundai air conditioner after losing ac remote. please help!
  • 960 Answers
You will need the codes that came with the general remote to match the Hyundai. Hyundai air conditioners may run the same codes as LG, Sharp , Daewoo so try the codes for those as well if you don't have luck with the Hyundai code
Posted on Oct 19, 2013
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
- check if the battery is still good
- check if the receiver of the unit is clean and no obstruction.
- Some of remote control have a reset switch, every time you change it with battery you have to reset it.
- Some of remote control have A and B selector at board and remote control, check this if they set at the same frequency.
- To check if the remote control still working you have to test your remote control to other unit with same model as yours. If its not working then replace your remote control. But if its working then you have to replace your receiver board.
- Some remote control have to be reconfigure so you have to read your manual.
Posted on Dec 29, 2007
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 15 Answers
SOURCE: Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Posted on Sep 18, 2008
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
SOURCE: Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Posted on Jun 02, 2009
How do I program a universal remote to my haier air condioner I lost my original remote
Most universal remotes won't have a code for an air conditioner. You'll need one that is made to work with A/C systems. See: http://www.amazon.com/HQRP-HWR08XC7-T-HWR10XC5-T-HWR10XC6-T-Conditioner/dp/B00VQ1NEUU or http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=AC-5620-30 for remotes that will work with the HWR10XC6 and some other Haier air conditioners.
I hope this helps. Please add a comment with the model and manufacturer of the universal remote you have. I'll try to confirm the available codes and how to program the unit.
May 27, 2016 | Haier hwr10xc6 Air Conditioner
How do i sync a fujitsu ar-dl2 air conditioning remote with air conditioning unit
Here is a link to current units: http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)ASU24CL-30CLX-36CLX.pdf
there is no indication that synching is required for OEM remotes, just chack and make sure the batteries are good. If it is a universal type remote, the remote manufacturer provides those instructions.
Nov 26, 2014 | Fujitsu Heating & Cooling
Need new remote
Most "generic" remotes can be programmed to work on most brands. Have a look at the back of the packet the remote comes in, it will show which makes / models the remote can be programmed to. In a lot of cases, the generic remote is a lot cheaper than a genuine one however some functions may not be accessible. IE/ Sleep or timer function. Dick Smith electronics or a general electronics store may have them or an air conditioner parts outlet will have them such as Heatcraft, Airfridge, Airspares etc (In Australia)
Mar 29, 2014 | Heating & Cooling
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
GE AIR 600BTU WINDOW CONDITIONER AQV06LAM2 COMPRESSOR DOES NOT KICK ON AT ALL FAN WORKS AS IT SHOULD
The stat. could be bad, without a meter hard to trouble shoot, if the comp. is getting power and not working the start components could be bad. If I had only one meter it would be a amp clamp. And I hope that your unit is 6000 btu's or its very tiny :)
Jul 02, 2011 | General Electric Heating & Cooling
I GOT A "ANYCOMMAND UNIVERSAL
hold setup until the light stays on then enter one of the following 4 digit codes: 1664, 1652, 1651, 1650, 1674, 1673
May 16, 2011 | Heating & Cooling
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Broken remote control
yes i think ebay do general purpose controlers if not i know somewhere in the uk ,a company called srw telephone no. 0441273455530. website www.SRWOnLine.co.uk they do a universal remote control at 39 pounds. hope this helps.
Nov 17, 2006 | Soleus KFS-12GW Air Conditioner
Heating & Cooling Logo
220 people viewed this question
Top Hyundai Heating & Cooling Experts
cwradio73
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Heating and Cooling Expert? Answer questions, earn points and help others
