Question about Interactive Toy Concepts 2 BladeRunner RC Helicopter Replacement Parts Kits - Rotor Blades, Shaft Sp
Problems flying WiFli helicopter
Will not lift off ground.
Fixing an humming subwoofer
Filter capacitors in the amplifier or a broken ground (shield) wire. Check if there is a ground lift switch in your system and try it in both on and lift positions.
Aug 30, 2016 | Boston Acoustics Horizon MCS130 5.1 10in...
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
How do I replace motor mounts on a 1998 Honda Civic LX?
It is important to lift the car off the ground with stands to get under the vehicle, if you are working on ground mounts or if you need to lift the motor. If you do lift the motor with a jack, make sure to use a 4 by 4 to cushion the aluminum oil pan. Do not overlift engine, you can break the oil pan if not careful.
Mar 03, 2016 | 1998 Honda Civic LX
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Lift is out of vehicle and won't go up or down
Sounds like the jack screw has bound. That requires a complete disassembly and inspection to see if it just needs lubrication or a part.
Feb 27, 2013 | Pride Backpacker Avp Lift SSBPAVP
2007 Yukon Denali XL lift glass is opening when I use the fob to open the rear hatch. This causes me to be unable to then close the rear hatch via the fob
This sounds like you have a grounding problem with your hatch circuits. This type of malfunction usually occurs when two systems (the hatch lift and the Lift glass release) are supposed to be sharing the same ground, but one of the systems has a bad connector or a broken wire. It then "activates" the other system by grounding THROUGH the system that it is supposed to be sharing ground with.
What I would do in your case is to take a HARD look at the wires that are in the conduit that runs between the lift gate and the body. These wires flex every time the lift gate is opened and closed, and are prone to breakage.
The way you describe it, it sounds like the lift gate motor is losing contact at about 1/3 to 1/2 of the way up, and that is when it grabs ground through the glass release solenoid.
Jun 13, 2012 | 2007 GMC Yukon XL Denali
Electrical interference on a DELL laptop.
Try a ground lift on the audio desk Im guessin it phase issue
ground lift is a small grey or orange 2 prong mail and 3 prong female any hardware store will have them...FYI
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Interactive Toy Concepts 2 BladeRunner RC Helicopter Replacement Parts Kits - Rotor Blades, Shaft Sp Logo
183 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
