Bluetooth and wireless not working in asus k53sm lptp.
It was working fine but after i turnd it on after hibernation d wireless led not glowing and no devices can b conncted.d wlan icon shows a red cross.wireless console also nt wrking.devce manger nt showng nethng abt bluetooth
pankaj_dic
  • 1250 Answers
SOURCE: Asus X80L Bluetooth Not Working..
you have to switch on your bluetooth check it, its button will be there
rate this solution
Posted on Oct 16, 2008
SOURCE: WLan / broadcom hardware disappears
(Originally from BEBEJAZ)
Here's a quick fix for a HP DV6000 that can't connect to the
internet, no network adapter detected in device manager problem:
not long ago, i also experienced this problem
my "HP Pavilion DV6308NR" with Vista OS is not connecting to the
internet
and the network adapter is not found under device manager.
Even the HP Wireless Assistant is not working.
I turned it on but my laptop still says it's disabled.
after a month of turn off, wait for 5 minutes and plug again routine.
I decided to look into the system configuration and here's what I
did:
1. Restart PC
2. Enter "Setup" by pressing <F10> as soon as you see the HP logo
on you screen
3. Go to "System Configuration" by pressing the left button twice
4. Go to "Boot options" by pressing down button 4 times
5. Press Enter
6. Go to "Internal Network Adapter Boot" by pressing the the down
button 3 times, then check if its DISABLED (of which in my case
was)
7. Then press <F5 or F6> to ENABLE it.
8. Lastly, Press <F10> to Save and Exit, then Select YES.
9. After that, PC will continue its boot process and make sure
you're Wireless Assistant is switched on.
And Viola! I can connect to the internet again!
Posted on Nov 27, 2008
  • 44 Answers
SOURCE: dell vostro 1510 laptop bluetooth problem
boot to the BIOS (by turning your computer on the start tapping on F2) after that, on the left pane, look for wireless, (you can only navigate using the arrow keys. highlight wireless then hit Enter, after that highlight bluetooth check if its ENABLED, if it IS ENABLED, go to control Panel open the bluetooth icon, make sure that the device you are trying to hook up to the computer is on Discovery mode or the bluetooth wireless is activated, try searching for it (the device) see if it connects this time. Hit me back on the results.
Posted on Apr 28, 2009
lilianji
  • 47 Answers
SOURCE: Bluetooth is not working in Lenovo 3000 y500 notebook
Try restoring your computer to earlier time using System Restore,
on Explorer click Help menu - Help and Support Center and select Undo changes to your computer using System Restore.
Posted on Jun 06, 2009
  • 11 Answers
SOURCE: presario f730us wireless light stays red and in
This is a flaw with Nforce chipset and Broadcom wireless cards. But getting HP to admit to it is another story. Every F700 used on a daily basis will have their wireless fail. Here are the solutions to try and resolve this...
1. Buy and install new wireless card ( has worked for me numerous times. Cheapest solution, $25 BUT may not work)
2. Buy a USB wireless adapter (little bit more money but will definitely get you up and running $50)
3. Replace motherboard (refabed cost around $120 or so. There is a reason so many of these go bad... Thank you hp!)
Other than that don't believe it s software/virus problem as it is a pure bad hardware issue. I am still a fan of Compaq laptops.. Just have to ignore this little bubmle on some engineers work station :)
Posted on Sep 07, 2009
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 27, 2013 | Dell Computers & Internet
I have No wireless connections
Have you followed the procedure described on page 70 of the Asus User Guide for your laptop to use the Fn + F2 keys to turn on your wireless radio - and do you see the normal wireless led indicator lit?
If yes, then you will probably need to do a diagnose & repair (or troubleshoot problems) depending on which version of Windows you are using. Right click on the wireless connection indicator in the bottom right area of the Windows Status bar and take the option from there.
If you normally only hibernate your laptop rather than powering it off fully, try doing a full power off and restart as hibernation can sometimes get the wireless adapter in a strange state.
Lastly, check that you only have one wireless manager enabled, i.e. use the Windows Zero Configuration manager by preference.
Jan 14, 2012 | ASUS Computers & Internet
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
I have Gear Head KB5200W Wireless keyboard and mouse. It works fine but I have to unplug and then reinstall the USB receiver every time I reboot. How can I prevent this?
I can't think of any reason why just leaving it in wouldn't work. Otherwise try hibernating the computer instead of shutting down. (Unless a program requires you to reboot).
Oct 10, 2009 | Gear Head Wireless Bluetooth V 2.0 Desktop...
I need to activate my bluetooth in my IBM r52 model,how do i do
Press Fn+F5 to open the Wireless Radio Control and turn on the Integrated Bluetooth features.
Whenever you start the computer or resume operation after it has been in standby or hibernation mode, you must turn on the Bluetooth features.
Feb 23, 2009 | IBM ThinkPad R52 Notebook
Charging does not happen
I took mine back to Best Buy...I think it was a faulty bluetooth...the new one has worked for the past week...good luck!
Sep 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Computers & Internet Logo
David Payne
David Payne
