Question about Belkin Computers & Internet
Wpa key password for belkin.158 - Belkin Computers & Internet
5 Suggested Answers
govinda123
  • 2260 Answers
SOURCE: We forgot the WEP key or WPA Key for our Belkin G
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Posted on Dec 01, 2009
govinda123
  • 2260 Answers
SOURCE: WPA KEY?
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on May 20, 2010
SOURCE: just need to know where
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jan 14, 2011
SOURCE: Where do I find the
Hello cyndi0417.
If you have installed your router, and have a computer connected to it through one of the wired ports, you can follow these steps to find your WEP or WPA key.
Step 1.
Open a web browser of your choice, and in the address bar type in "192.168.2.1" (without the quotation marks).
Step 2.
Select "Login" from the upper right corner of the screen. Unless you have changed the administrator password, you can just click on the submit button.
Step 3.
Look under the "Wireless" heading on the left side of the page. There will be a selection for Security, which will contain the WEP or WPA settings. The numbers/letters in the boxes is your key.
Posted on Feb 01, 2011
Belkin model no.f5D8236-4v2 need security key
  • Open a web browser on the computer. In the address bar of the web browser, type http://192.168.2.1 and hit "Enter."
  • login using login details..
  1. Click on "Security" in the left-hand column under the "Wireless" heading.
  • Use the drop-down menu and select "WPA/WPA2-Personal (PSK)."
Select either "WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2" as your Authentication; doing this will set the Encryption Technique automatically.
  • Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
  • Click the "Apply Changes" button to save the settings.
  • You've now set up WPA/WPA2 security on your network.
For reference,follow this blog-----Belkin N F5D8236-4 Wireless Router
Sep 03, 2012 | Belkin Wireless Surf Router (F7D2301)
Wanna know how to secure my belkin wireless G router.
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed
Configure Wireless Security on Belkin Router - Enable WPA and WEP Why should we setup wireless Security on Belkin Wireless Router ?
After configuring your Belkin router you should secure your wireless network using proper wireless encryption. It can keep wireless hackers away from your wireless network and the unwanted sharing of your Internet connection. In order to know how to login and configure your Belkin wireless router click on the link below.
How to Setup Belkin Wireless Router
Setup Wireless Security in Belkin Wireless Router
Now I hope you just followed the steps mentioned in the above link and log in to your Belkin Wireless Router. In order to enable wireless security on your Belkin router click on Security Under wireless. ( Security tab present on the left side of Belkin configuration page).
You can select either WEP or WPA to secure your Belkin Wireless network. To know more about WPA and WEP click on the link below.
Which is better WEP or WPA on your Wireless network
Enable WEP in Belkin Wireless Router
To select WEP for your Belkin wireless network ,click on security mode drop menu and select WEP. WEP is of two kinds WEP 64 bit encryption and WEP 128 bit wireless encryption. You can type your PassPhrase and generate instant wireless key for your Belkin wireless network.
After generating the wireless key, you should save settings by click on Apply changes. Now onwards to login to your Belkin wireless network, you need this wireless key.
Enable WPA in Belkin Wireless Router
WPA is more secure than WEP. To enable WPA on your Belkin router, select WPA from security mode drop down menu.
You should enter a pre-shared key to enable WPA security on your Router. Don't forget to save this WPA settings.
Aug 28, 2011 | Computers & Internet
I have a belkin wireless router I have one laptop connected to it now I want to connect another laptop to it but I forgot the password how can I find it?
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 01, 2011 | Belkin Computers & Internet
Network router key and password
Step 1: Connect your Belkin Wireless Router to your Desktop or Laptop with a cable on anyone of the 4 Wired Slots.
Step 2:Open Internet Explorer and type http://192.168.2.1
Step 3:You should be seeing Belkin Router Setup Utility
Step 4:Now on the left hand side Under Wireless click onSecurity.
Step 5:It will ask for login and by default there is no password,so click on submit.
Step 6:You will have the security mode over here and if the security mode is WEP then under Key 1 will be the password or
Security mode is WPA means uncheck the Obscure PSK on the bottom and you will having the WPA password under Pre Shared Key
So that will be your wireless password
Regards,
Pugalenthi.I
Dec 27, 2010 | Belkin (F5D7230-4) Router (587009)
I lost my wpa key? Can I find this somewhere?
Yes, you can get the wpa key from the setup page of the router.
Type 192.168.2.1 in the address bar of your web browser.
By default, leave the password blank.
Once in the setup page, go to Wireless > Security.
You will find there the WPA pre-shared key.
I hope this helps!
May 11, 2010 | Belkin (F5D8231-4) Wireless Router...
Tryig to connect my ps3 over wireless connection to my belkin f5d8236-4...its asking for a wpa key
Hi Johnny,
Please follow the below steps,
1.type 192.168.2.1 in the internet explore
2.you will be able to see the Belkin router setup
3.in your left hand side,you will see the menu "security below wireless"
4.it will ask for password leave it blank and click on submit
5.now you will be able to see the WPA key,
if it shows in dots,then uncheck the "obscer PSK" box now you will be able to see the WPA key.
Regards,
Ayyasam
Dec 30, 2009 | Belkin F5D8236-4 Router
Just bought second hand router belkin 54g trying to set up with ps3 it is asking 4 a wpa key and i dont know what to do can you help
the old owner of your router know the wpa code he/she inputed you must ask him wat is the wpa code since you are now the new owner you shold chnage also the old wpa code to new one....
Oct 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I find out my Belkin Security Code?
You will need to access the set up interface of the router.
The security code will be on the router set up interface.
Click Here to know more about how to access the set up interface and routers
Oct 26, 2009 | Belkin (F5D7231-4) Wireless Router
I have forgot my wpa key help
Unforunately you cannot recover a lost WPA key. It negates the purpose of the key. You will have to log on to the router and create a new one and make sure all connecting clients have a matching key.
Steps are located here:
http://www.belkin.com/support/Network_Support_Wizard/Setting_up_wireless_security.asp
Jul 07, 2009 | Belkin (F5D5230-4) Router
Cant get may psp and my wii consoles to work
This is the password to your wireless network.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
