Question about Ovens
How do I change the thermocouple on a beko gas oven dvg695
2 Suggested Answers
SOURCE: I have a BEko 'Leisure alta AL6ND' oven. The
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Posted on Mar 18, 2010
Testimonial: "Pretty much spot on. Thanks. "
Where is a gas fuse in a Kenmore oven?
Gas ovens don't have a fuse. Won't the oven light?
Pilot Light won't stay lit?
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Posted by Andrew... on Jan 17, 2016
Jan 26, 2016 | Kenmore Ovens
Hi my beko alta al6cdw cooker isn't getting hot the fan is working and its warm but not hot
assuming its the oven. check element or the thermocouple
Mar 23, 2015 | Ovens
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Oven no gas
pilote tube could be blocked or pilot orifice set too small. check that the gas pressure is ok
Jun 07, 2010 | Stoves 600GR Gas Single Oven
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
Dec 01, 2009 | Ovens
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
Morning I need help please regarding my gas oven (Beko SCG7530). The problem is when i turn the gas knob on,(push and hold for say 10 secs)the oven works fine,but as soon as the knob is released the gas...
Sugar,
Sometimes it takes a minute or longer for the thermocouple to get hot enough to send the correct voltage to the main part of the gas valve to get it open & the burners to light. If after a few attempts of turning the pilot knob to off, waiting a couple of minutes and then going thru the lighting process, your problem is the thermocouple. Most repair companies will NOT install YOUR parts because of the liability & warranty issue. The best bet is to call a repair co & explain what the problem is & tell them to bring a thermocouple with them. Sears or calling your local BBB is your best course.
Jul 09, 2009 | Ovens
Ovens Logo
109 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
