Question about Mitsubishi WS-65807 65" Rear Projection Television
No picture or sound
When I turn on my TV there is no sound or picture. When looking through the rear of the TV I can see that there are lights on so it is getting power and stays on. I checked to verify our cable was connected properly and also pushed the A/V reset button on the TV panel. I even unplugged the TV for a while to see if that would make a difference. A friend of mine said it might be a bad signal board. Does this make sense? If so, what's the cost to replace?
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
Posted on Sep 05, 2007
SOURCE:
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hitachi Rear Projection TV won't operate aftter circuit breaker was tripped.
Well pard, obviously that power glitch buggered up something. That tv is pretty complicated. The main microprocessor could be outta commision. The power supply appears to be ok, at least partially. I could get in there with a meter and scope and figger it out. But you probably need to have a reputable shop look at it. BTW that's a good set and worth keeping going.
May 28, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at [email protected].
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Have sound but no picture
YOU HAVE A BAD CONVERGENCE IC ON THE CONVERGENCE CIRCUIT BOARD-THIS PART CAN BE REPLACED ,SAVING SOME MONEY,,COULD ALSO BE A LOOSE CONNECTION ON THE IC...PROBABLLY NEED TECH ON THIS ONE --COST 'BOUT 100.00 TO 125.00!
Aug 04, 2007 | GE 46GW945 46" Rear Projection Television
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
