Question about Uniden Ubc-3500xlt 2500 Channel Radio Scanner With Close Call. From The Uk
Replacement internal speaker for UBC-3500xlt
Please where can i find one
How do I fix the internal speaker sound of HP 3380 MT?
The earphone connector may be defective and will have to be replaced.
Jan 19, 2016 | HP Computers & Internet
Reset my uniden ubc3500xlt
Scanner Reset: To initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on. Important! This deletes all preprogrammed data. You cannot restore preprogrammed data that has been deleted.
Jul 09, 2014 | Uniden UBC-3500XLT Handheld Scanner...
Battery error on screen
you need to replace the battery. they don't last forever. do a search an you can purchase an new battery without having to solder them in yourself.
Mar 22, 2014 | Uniden UBC-3500XLT Handheld Scanner...
I can't hear any sound during the camcorder playback mood, but there is no problem to hear while connection on TV.
It seems internal/ inbuilt little speaker is bad that is why you do not get sound in camcorder itself during playback. Please check internal speaker and replace it to get sound.
Let me know exact model number written on bottom of camcorder to provide you speaker part number , if required OR take it in local camera repair shop for speaker replacement.
Thanks.
Nov 15, 2010 | Sony DCR-SR40E Mini DV Digital Camcorder
Garmin automobile power imput
the "fm" 700 series and some 600 & 800 now not being sold
Dec 27, 2009 | GPS
Distored sound
distorted sound from external speakers or internal speakers?
isolate please. remove external speakers if you have one. just troubleshoot on the internal speakers alone.
uninstall the audio drivers. install the latest one. if fails. download then flashed the latest bios.
run diagnostics extended test to check the internal speakers. if also fails then replace the internal speakers.
Dec 05, 2009 | Computers & Internet
I HAVE A UNIDEN UBC73XLT
The BC72XLT is a USA model scanner, while the UBC73XLT is produced for Australia and New Zealand. The two are very similar, but not identical. There is a slight difference in frequency coverage (it's a bit wider on the UBC), the BC comes with a 110-volt AC power supply (wall-wart) for USA use, while the UBC comes with a 12-volt DC vehicle power supply.
FYI, here are links to the operating manuals for both models:
http://www.uniden.com/pdf/BC72XLTom.pdf
http://www.uniden.com.au/resources_main/pdfs/UBC73XLT_OM.pdf
Feb 16, 2009 | Uniden BC72XLT Handheld Scanner
Uniden UBC 30XLT serial n~74002043
Hi - You can download the manual from the link underlined in blue below:
UBC 30XLT
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 17, 2008 | Uniden BC72XLT Handheld Scanner
Uniden Ubc-3500xlt 2500 Channel Radio Scanner With Close Call. From The Uk Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
