Question about Ovens
Beko gas oven dvg695 will not stay alight - Ovens
  • 59 Answers
SOURCE: My oven won't heat up properly
wire brush the oven pilot light orifix flame may be lessened due to carbon buildup then when oven lights its convextion pulls the pilot flame away from thermal coupling with shuts off gas (in case wind blows it out, it will STOP the GAS FLOWING. if the pilot full size (near 3/4 inch tall) then just try to position the thermal coupling nearer the flame (not right on it)
Posted on Nov 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Describe what could be the problem if my oven will
That could be one of 3 things: The thermocouple could be bad, the hole that the thermocouple screws into could have corrosion and causing a loss of electrical current to the safety magnet. Or the safety magnet itself is bad. The thermocouple when heated generates electricity. The magnet inside the valve is powered by the thermocouple. If the pilot light goes out the magne looses energy and the spring attached to it shuts off the flow of gas. Pretty clever ain't it?
Posted on Jan 20, 2010
SOURCE: I have a Beko gas cooker model DVG695 and although
Check the thermocouple is in the correct position. If it is you may need a new one.
Posted on May 08, 2010
SOURCE: Beko SCG 7521 gas cooker flame won't stay lit in oven
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Posted on May 15, 2010
tunde007
  • 2382 Answers
SOURCE: My SMEG oven won't stay
Hi, it is your thermocouple. It's worth having a look first prior to getting someone to replace it though. You will see a small "probe" that sits in the flame which is the thermocouple, this is the fail safe device that cuts off the gas should the flame go out. When it heats up it keeps the gas on but when it cools (when the flame goes out) it will not let any gas through unless you have the knob held in. Three checks:
  • look at the end of the probe and see if it's sitting in the flame, it may have been knocked to one side during use or cleaning which will prevent it working - gently push it back into place and try again.
  • Has the probe become covered in grease etc which is preventing it working properly - clean with a rag and try again.
  • Is the end of the probe heavily corroded - if so will need replacing.
  • Sometimes they just get tired so will require slightly longer to warm up and hold. When you light the stove hold the knob in for 15 seconds and see if it holds then.
If none of the above work get a gas safe chappie round and put you a new one in.
Posted on Dec 22, 2010
Is there an adjustment to have pilot light stay on after given length if time. Our rev oven pilot takes longer then one minute. About 1 1/2 min
No it is a safety feature that the pilot has to heat up the thermocouple to assure the main gas valve that the pilot is alight and hot.
Dec 05, 2016 | Ovens
THE GRILL ON MY ZANUSSI ZXC662GXC COOKER WILL NOT STAY ALIGHT
you will need to contact your local Gas Safe service engineer, you are not permitted to repair this yourself. check the Gas Safe website to find your local service engineer.
Sep 03, 2016 | Zanussi Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
Nov 22, 2009 | Ovens
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
Oct 08, 2009 | Ovens
Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Nov 18, 2007 | Ovens
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
