Horizontal lines across the screen and bad distortion on right hand side
We are getting horizontal lines across the screen about 4" apart plus on the right hand side of the screen we are getting the picture repeating itself (ie when the weather forecast comes on, the difference place names we can see about four or five of them underneath each other). An engineer has told me (over the phone that he thinks it's an inverter board, but after reading some of the things re inverter boards I don't know if it is or not). The tv is a Samsung LCD - model LE40F86BDX/XEU. We have had the tv for six years this October and until recently we had no problem whatsoever.
tvservice306
  • 458 Answers
SOURCE: horizontal lines on tv
TRY REPLACED T-CON BOARD
Manufacturer Samsung Part Number BN81-01312A Description A/S-T CON BOARD
Posted on Dec 17, 2009
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
SOURCE: Horizontal lines across right side of screen
THIS SEEME LIKE A LOGIC BOARD OR LVDS CABLE COST ABOUT 300 DOLLARS
Posted on May 31, 2010
SOURCE: RCA LCD TV INVERTER BOARD
The problem is not in the inverter board it is in the power supply R976 is fried. I need to fined the value of that resistor.
Posted on Jul 20, 2012
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Screen has horizontal lines and fading
bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Feb 09, 2008 | Computers & Internet
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
I have a Flat screen Sony Bravia KDL-46S4100. Lines go across the screen horizontally about 6 inches apart. There is distortion especially on the right side mostly on lower right. What needs to be done to...
Like this??
Thanks!!
nc
Apr 02, 2010 | Televison & Video
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Picture distortion on bottom left of the screen
Probably bad convergence amp ICs on the signal board.NOT something to tackle unless you are experienced tech.because they will sometimes open resistors in the circuit also.
Jan 11, 2009 | Toshiba 50H82 50" Rear Projection...
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
