Question about Sony Cyber-Shot DSC-S60 Digital Camera
Lens does not retact and camera does not work
The camera always has lens open. I have tried restarting and powering off but it does not work
  • 1 more comment
  • flossie2 Nov 14, 2007
    lens only retracts part way. checked batteries and they are good. the word
    "access" comes up on screen.
  • Typi Dec 15, 2007
    Lens is part way retracted, access comes up on screen, no way to take pictures or review them either.
  • crash n burn Dec 23, 2008
    lens doesn't retract and access appears on window can aceess the photos to look at them but can't take photos
Solution #2 posted on Jun 30, 2008 Lens does not retact and camera does not work - 0%20stars_w.png
nLens does not retact and camera does not work - nonexpert_s.gif> Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks! IT worked! Awesome! I love this camera of mine and now after three years of ownership it works again! I thought I would try this fix because I have nothing to lose since the cost of fixing the camera would be more than actually buying a new camera.
My problems began when I left my Sony DSC-S60 camera in a very hot car. My genius brother and nephew said the temperture and humidity expanded some of the gears and/or the opening mechanism. They said I would have to take it in for repair or just buy a new one.
I tried new batteries, and jarring and banging the camera somewhat lightly at first on a countertop with no success. I even thought of putting it in a plastic container in the freezer for a few hours to see if I could undue the "heat damage".
At any rate, I just saw this posting and I just dropped it twice on a hard carpeted floor, (truly hard -concrete underneath the carpeting with minimal or no padding) and EUREKA!! It works! It works!!
I might caution those trying this great fix, avoid concrete or tile floors and when you "drop" the camera do so from waist hight at first and try to get the camera to hit on the bottom of the camera, not the delicate front (the lens aperature) fo the camera.
Wow! am I ever happy. My camera back in time for the holidays AND NO MORE LEAVING IT IN A HOT CAR OR OTHER INCLEMENT CONDITIONS!!!! Good luck friends.
Comment by nova678, posted on Jun 30, 2008 Thanks! IT worked! Awesome! I love this camera of mine and now after three years of ownership it works again! I thought I would try this fix because I have nothing to lose since the cost of fixing the camera would be more than actually buying a new camera.
Posted on Jun 30, 2008
Dear Sweet Rascal,
Have removed the battery from the cam for more than a minute and have inserted it once again, but the cam still prompted "Lens error, restart camera," then the cam automatically shuts down. please advise.
Posted on Dec 31, 2007
The url below was published just a day or so ago. I have fixed 2 dsc-s60 cameras that where purchased from Ebay with Lens problems. http://www.nichewebworks.com/~tht/ The server is on a Slow Connection. Thomas
Posted on Sep 29, 2007
    Problem Solver:
  • 36 Answers
Try to initialize the unit, menu>setup>setup1>initialize. If no effect, lens assy, needs replacement. thanks
Posted on Sep 14, 2007
SOURCE:
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon lens cover won't open
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Sony Cyber-Shot DSC-S60 Digital Camera Logo
226 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
