Seiko qr 550
Error e-39
I keep getting an error when i scan tHE QR code
What error are you getting? Where is your QR code on?
Thank you
M
Sep 09, 2017 | Cars & Trucks
Tip
Swann wireless cameras will not connect to the cloud after the recent update.
Uninstall the Swann app from your mobile device.
Use a pc or laptop and log into your network connections and navigate to wireless password settings and change the password for the network that your problem camera connects to. This will keep your camera from auto connecting. You will add them back later.
Restart your router. When the network is back online log in again , and confirm that cameras are no longer connected. You do not have to power the camera off.
NOTE: (You will have to repeat the following steps for each camera. Do not use the same qr code on more than one camera)
Open a browser window and navigate to the Swann cloud website. (https://www.swann-cloud.com) and log into your account.
Navigate to the camera tab and check to see if your cameras are in the camera list. Delete all non working cameras from the list and log out. (As a precaution, you should download any events that you want saved to prevent them from being removed. Or only remove one camera at a time when you are deleting cameras).
Reboot your pc or laptop and log back into the website and navigate back to the camera tab and select
Select the option you prefer. (Usually wifi unless your camera is plugged directly into your router wired option is useless)
Enter your wifi logon and password
You should now see the qr code with two options. Select for the old qr code. It should automatically show the highlighted and display a qr code.
Using your cell phone, open the camera and take a clear picture of the qr code, make sure that the picture of the qr code fills the screen so it isn't too small.
Locate the picture in your photo gallery (I recommend that you crop the picture so that only the qr code is visible)
NOTE: Do not log out of the Swann cloud website or close the qr code window from here, it must remain open. Leave the qr code on the screen.
on Mar 23, 2017 | SWANN Home Security
SEIKO Precision QR - 350 error code E-38
The problem is the bar which runs the printhead.
When the head was stuck, I mean, does not move, is when get the error.
What I did was oil the bar so that the head can move without binding.
If you had a kind of solid fat for this machine would be better but I do not know what kind.
So personally I solved this problem.
Greetings.
May 27, 2014 | Kitchen Appliances - Others
Need help identifying watch
Take it to a local jeweler and they will tell you all about it for free.
Search Results
How to tell when your Seiko watch was made (Part 1)
quartzimodo.com/how-to-tell-when-your-seiko-watch-was-made-part-1/ Sep 21, 2010 - If you can't see the serial number on the glass, then look for them on the caseback ... Every Seiko watch manufactured is given a 6-digit serial number. ...... Your old Seiko watch is likely to be from the Seiko Sportsmatic or the ...
WatchSleuth - Seiko Date Finder
www.watchsleuth.com/seikodatefinder/ Seiko Date Finder - Find out when your Seiko watch was made. ... In the example images the serial number is highlighted in blue. Every watch has a unique combination of reference ... the watch was made. Looking at the example images:.
Watch Finder ' Seiko
www.seiko.com.au/collections/seiko-watch-finder Watch Finder. Seiko Watch Finder ยท Seiko Clock Finder. Search by Model Number. Collection. - Any -, Grand Seiko, Astron, Prospex Platinum, Prospex, Presage
images below
older seiko watch with dubai australia chicago on bezel Google Search
Jul 31, 2017 | Seiko Watches
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
I need to get a spare bracelet link for a Seiko SMA075. Where is it available? Thank you.
You can get bracelet links for Seiko watches at Coserv, Seiko's main repair center located in New Jersey. The phone number to Coserv is 1-800-722-4452. If for some reason your links are discontinued occasionally a local watch repairman will have spare links! I hope this helps!
Sep 14, 2011 | Seiko SMA075 Wrist Watch
Technical details of permanent failure: Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about...
That's not from an OS. That's from an MX. See the IRCs about email for details and reasons your message was bounced. In general, either you didn't get the address right or the address doesn't exist anymore, and there is no place sensible to forward it.
Jun 07, 2011 | Computers & Internet
I cant find a app for my HTC HD 2 to view and read QR codes, who can help me with a link and manual for this app
Barcode Scanner is required to read the QR code. To get the app, open the Android Market and start a search for "Barcode." You'll see several options, but ignore all of them and scroll down to an app labeled "Barcode Scanner" and download the application.
Jun 01, 2011 | HTC Desire HD Cell Phone
We have a seiko precision clock in / out machine model QR- 375 which is displaying error 38. plz help me to fix it
Hi it means that print head not going back to home position to complete it's process. Need to contact service center to repair and get the machine serviced on 1300 136 401 Australia wide.
Mar 28, 2011 | Office Equipment & Supplies
21 people viewed this question
jasbo
jasbo
