Question about Air Tools & Compressors
Ridgid air Compressors 5 in 1 Mobil Air OF50150TS won't build up pressure
SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Posted on Apr 01, 2009
SOURCE: craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Posted on Apr 23, 2009
  • 59 Answers
SOURCE: Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
Posted on May 25, 2009
lester482529
  • 226 Answers
SOURCE: air compressor slow to build air pressure.
you might need to checktosee if the filter is blocked or dirty were the air intake is just like a car dirt can build up there.
Posted on May 26, 2009
lester482529
  • 226 Answers
SOURCE: no air pressure
TRY ADJISTING THE TANK PRESSURE KNOB WHILE RUNNING ,TURN TO THE RIGHT 1/4 TURN UNTILL YOU SEE NEEDLE MOVE .MOST TIMES FACTORY SETS AT 0,SO YOU NEED TO ADJUST IT .MY ADVICE IS NO MORE THAN 90-100 PSI TILL YOU KNOW WHAT YOUR RUNNING MORE OFTEN
Posted on May 27, 2009
Compressor shuts off before it has reached pressure
probably mis adjusted cut off valve... not something we recommend doing as it could lead to catastrophic failure
Dec 30, 2013 | Ridgid FactoryReconditioned 12 HP 5Gallon...
Motor trips O/L when compressor tries to restart after pressure drop.
there is a check valve at the bottom of the one gallon tank, the spring is corroded and collapsed. air is passing the valve and getting to the top of the piston head causing the piston not to move. sometimes you can reseat the valve seal if the spring is good by putting the seal metal rod in a small drill and turning it
on the seat a dozen turns this cleans the seat a makes it seat better. the third fix is a bad reset switch. some times a bad capacitor is the problem.try I known good one . good luck , lee
Nov 12, 2013 | Ridgid Tri-stack 5-gal. Portable Electric...
Compressor wont build air pressure only to 40 lbs
Have you checked the regulator setting? If you tighten the regulator down to the lowest setting and let it set for 30 minutes this may well re seat the valve face. So 1. Tighten the regulator to as tight as you can NO TOOLS just by hand. Let the unit set for 30 minutes. Unccrew the regulator know to the highest value. 2. Fire up the unit and test.
You may be joyously surprised. Otherwise it's likely a leak that only opens above 40 psi. If that is the case then you can let the unit run to load at 40 psi. Then with 1/4 cup of dawn dish detergent and 1/2 cup of warm water mixed together. Disconnect the unit from power. Mix the soap and water then pour over the joints of the unit and the drain spigot. The Drain spigot can sometimes become blocked partially open when a flake of rust becomes lodged at the valve face after draining. If so you will find the leak when the soap hit the spigot. Lots of bubbles indicated leak.
Hope this helps. I have seen issues at the reed valve on the compressor where one or two of the screws that hold the reed valve to the cylinder head beome loose.
Nov 09, 2013 | Ridgid OF50150TS Pressure Switch
EASTMAN11607 WON'T BUILD PRESSURE, MAYBE IT'S THE REED?
try puttingafew drops of linseed oil in the air intake, if it is oilless, or check to see if the oil is too low if it is the oil type.
Oct 06, 2012 | Air Tools & Compressors
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Pressure release keeps kicking off
The pressure switch is faulty needs to be calibrated.
Jun 22, 2012 | Ridgid 17048 Gas Powered Wheelbarrow Air...
Will not allow me to regulate air. compressor kicks on and builds to max pressure.
All air compressors build pressure in the tank(s) to their maximum allowed by the pressure switch. The regulator only controls the pressure of the air available at the outlet. That's why they have two pressure guages, one for tank pressure and one for outlet pressure. If you cannot control the air pressure at the outlet then you have a defective/broken regulator. Dewalt does not make the regulator as a seperate part for their air compressors, you have to buy the entire manifold which includes a regulator to fix this problem.
Jan 31, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
Air Tools & Compressors Logo
129 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
