Question about Cameras
Dvr says no hard disk
Just stop recording
3 Suggested Answers
TBlessed 1
  • 61 Answers
SOURCE: Recording from DVR to DVD Recorder ?
please tell us what models do you have
Posted on Nov 12, 2008
brownline45
  • 310 Answers
SOURCE: My DVR-633H records on the hard disk but freezes
maybe the dvr stock up in reading so it freezes. its time to check up the mechanical of your dvr
Posted on Jun 19, 2010
How to export recorded video on a Pelco DX8100 DVR?
Converting Pelco exported video files
WHAT IS A DVR?
A DVR is a video recording and pl
ayback device that inco
rporates all of the essential capa
bilities of a VCR but adds significan
t advantages. Like
a VCR, video is recorded from one or more cameras and stored for later playback and retrieval; however, in a DVR, video data is
recorded and
stored on a hard disk instead of
magnetic tape.
Storing video in
this manner facilitates
instant, rand
om access to data, as opp
osed to sequential
access inherent to tape-based recording. This means no fast-forwarding or rewinding is necessary to locate the data a user want
s to view or
export. Another key advantage over tape is decreased maintenance. With no need to replace tapes, DVRs with hard disks can be le
ft unattended
for extended periods of time. Since video remains in the digital domain, data is easy to store, transport, and manipulate. Unli
ke analog video
recordings, digital data does not suffer from a loss in quality wh
en copied or moved from device to device. Because DVRs rely o
n hard disks
instead of tape, data storage is virtually unlimited. Video data
can also take advantage of comp
ression technology
to increase
the efficiency of
storage media. Modern DVRs, such as the DX8000, allow users to record, play back, and view live video simultaneously. Keeping d
ata digital
means video can be easily backed up to a variety of storage media.
It also means that alphanumeric
information, such as date, t
ime, and
transaction statistics,
can be synchronously recorded with video.
Jun 20, 2015 | Pelco Televison & Video
How can i transfer programs from a dvr to my dvd recorder?
No, most DVRs do not allow copies to be made to disk, etc.. Some like Dish, do allow you copy to an external hard drive for back up storage and viewing through the DVR.
You need to check with the mfg. of your DVR or service provider.
Jun 11, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
My picture breaks up and I loose sound. usually while viewing something I've recorded on my DVR. is it my tv or the cable? or the channel itself?
If it is only during watching a recording on the DVR then it may be the DVR that is the problem. Does a recording always break up at the same point? If so then the recording itself is bad and this may be due to a poor signal being received. If the breakup occurs randomly then the DVR may not be able to read the data from the recording media (Hard disk or DVD - you did not specify). The obvious first step is to try the DVR on another TV.
May 16, 2011 | HP Lc3272n 32 in. LCD Television
I bought a "My DVR Expander" to use with my DirecTV HD DVR. Does Western Digital make this expander in anything larger than 1TB? If so, where can I buy one?
Note that your DVR will treat this as "extra" storage, i.e., supplemental to its "internal" storage.
A 1 terabyte hard drive allows you to record:
  • Up to an additional 600 hours of Digital TV
  • Up to an additional 120 hours of High Definition TV
Since the largest EIDE/PATA disk-drive is 0.5 TB, the disk-drive inside the Expander must be a SATA disk-drive.
So, disassemble the unit, disconnect the SATA disk-drive, and pay about $300 to buy a "2000Gb Western Digital Caviar RE4 Raid Edition 7200RPM 64 Mb Cache 3.5 7200RPM 64 MB Cache SATA Internal HD 3 Yr Warranty WD2003FYYS".
Connect the disk-drive to its interface.
Close-up the case.
Connect your "custom" PVR expander to your DVR,
and see if your DVR will recognize the 2TB of disk-storage.
Sep 08, 2010 | Western Digital My Book Essential Edition...
Toshiba dr410 dvr stops recording after 9 minutes. Doesn't matter if I use timer record or press the record button. There is a box in the lower right when you hit record which says sp-09 as if it is...
go to your setup menu and shut all timers off...(are you trying to record HBO...this will occur when trying to record any of HBO/Disney) check your manual and make sure you have the right type of disk...+/- makes a big difference
May 20, 2010 | Toshiba DR410 DVD Recorder
Copying CCTV DVR data to external HDD for storing data
use the software that comes with ur dvr. connect to it via lan.. and save the infor in to ur computer
May 15, 2010 | Western Digital Passport WDXML800UE...
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
Cameras Logo
61 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
