Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Release for a Black&Decker ODC400 space saver
I have a Black and Decker ODC400 that I need to slide out of the bracket that holds it under the shelf but I can't seem to find the release for it. HELP!!
  • 30 Answers
There's no release. Rock the bottom of the unit forward then pull towards you and it should come free. The catch is actually at the top of the unit where it meets the slides on either side.
Posted on Mar 28, 2008
I have a Black and Decker ODC 460--it has been recalled BUT they want the data on the back of the unit. It is suspended from a cabinet and though they suggest it can be removed from the mounting kit...
The Use and Care Manual for your product can be found here:
http://useandcaremanuals.com/pdf/ODC460973.pdf
REMOVING THE UNIT
1. To remove unit from mounting bracket (for service or cleaning), first remove the thermal carafe. Slide your hand under the unit for support. Slide unit forward on its track guides to remove.
2. To replace the unit, slide it onto mounting bracket and all the way back until it locks into place.
Your right that they do not provide any specific instruction on whether there is a lock to release. I suspect you need to lift the unit up in the tracks before you pull forward.
Apr 25, 2011 | Black & Decker ODC460 Coffee Maker
How is the ODC325 removed? Its mounted in an RV and appears to have no screws or release system. Thanks
The machine slides into the side brackets and drops into slots on either side. Lift the entire unit up a half-inch or so and slide it forward (toward you).
Apr 12, 2011 | Black & Decker SpaceMaker ODC325 Coffee...
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
My under the cabinet coffeemaker turn off before finishing brew.
mcdevito75 here, You can make sure the coffee maker is plugged inot the wall socket, check that the machine is in ready condition, pot in right place, filter in right place, also chech house fuses.
Jun 28, 2010 | Black & Decker ODC400 10-Cup Coffee Maker
No instructions on how to mount spacesaver coffe maker
Email Black and Decker here
support.blackanddecker@bdkmail.com
If the publication you require is not available online please provide your full name, complete mailing address including city, state, and zip code/postal code, your daytime phone number in case we have a question regarding your request, and most importantly the Catalog number and type number of the product you are writing about. The catalog and type number can be found on the nameplate of your product.
Jan 30, 2010 | Black & Decker 12-Cup Programmable...
Odc 325 Under the Countor
Grasp the coffeee maker assemby firmly and pull it froward (away from the wall). The The unit willl slide slightly forward in the hanging brackets leaving about 1/4 in of space exposed between the front of the hanging bracket and the main assembly. Insert a kitchen knife of flat-bladed screwdriver into that narrow space until you are pushing the plastic hanging bracket catch inwards, holding it there. If you are working alone, alternate this maneuver on the right and left sides while maintaining forward pulling pressure on the main assembly . It will eventually slide forward and out of the hanging brackets. It will be far easier and faster if you have a helper to help you push in both hanger bracket clips at the same time while keeping forward pulling pressure on the coffee maker. , because no one has three hands. Done this many times
Jan 27, 2009 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker BDTF1010B Tower
when you take all the screws out slide the back down. there is a screw at the bottom holding it from slideing the 9th screw so to speak. you have to take out the u shaped pin on the rod once that u shaped pin is out thats where you will find all the screws to the bracket holding the moter in place take all those out too. it seems like alot but it is really not.
Jul 12, 2008 | Black & Decker BDTF1010B Tower Fan
Black & decker spacemaker odc440
Lift the entire unit from underneath and slide it out of the bracket.If that doesn't work, undo the screws from the inside of the cupboard.
Jun 17, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
129 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
