Question about Honda 2012 Odyssey EX-L
2012 HONDA ODYSSEY DOOR STUCK OPEN
Drive side sliding door stuck in open position; does not respond to manual or auto closing; other door is fine
It's possible the fuel door was left opened when the power slider opened? Turn off the power slider switch on the left side of the dash board (left of the steering wheel), then manually close the slider. Close the fuel door then turn the power switch back on. If it continues to jam, turn off the power switch again and open/close manually until you can get it to the dealer.
Posted on Oct 25, 2013
2012 dodge grand caravan side door won't stay closed
Dodge grand caravan door won't latch easy fix - YouTube
? 1:04
www.youtube.com/watch?v=MxcvPkCd70M
Dec 12, 2013 - Uploaded by Jason Sikkema
2003 passenger sliding door won't close, this maybe the problem. ... Out-of-Synch Liftgate Latch DIY Fix - 2012 Dodge Grand Caravan ...
2011 Dodge Grand Caravan passenger sliding doors will ...
? 0:16
www.youtube.com/watch?v=tJeuH9DhYG0
Nov 5, 2013 - Uploaded by 3fourjay
2011 Dodge Grand Caravan passenger sliding doors will randomly shut ... The fob would cause it to close at random positions during opening. ... be widespread and Chrysler won't do anything unless it becomes a public issue for them. ... Out-of-Synch Liftgate Latch DIY Fix - 2012 Dodge Grand Caravan ...
Oct 19, 2015 | Dodge 2012 Grand Caravan Crew
My honda odyssey ex 2008 the doors do not move on
Do a reset on the door system, by pulling the door fuse. I don't have location, possibly drivers side fuse box.
Sep 15, 2014 | 2008 Honda Odyssey
Sliding rear door stuck in open position
Is it a power slider? What side is it? If it's a power slider it's possible the fuel door was left opened when the door was opened? If so, turn off the power slider switch on the left side dashboard (left of the steering wheel), then manually close the door. Make sure the fuel door is closed before turning it back on.
Jul 26, 2013 | Honda 2012 Odyssey EX-L
On my 2003 Odyssey the passenger side sliding
yes with little ingenuity, and a kit from your local dealer.
Apr 17, 2010 | 2002 Honda Odyssey
The sliding doors on our 2006 Honda Odyssey
Happened to me today on my 2007 non-powered slider. Big snowstorm, lots of ice. I forced the door open from the outside and could not close it. Lots of fun driving home. I let it thaw in the garage and saw that the assembly was engaging, the lock was still spring loaded....and it works now. Last year, on the other side of the car, the slider would not close and it was because the assembly lost its spring. Dealer had to take the whole door off and replace the part. 500+ dollars.
Sep 19, 2009 | 2007 Honda Odyssey
Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
Apr 11, 2009 | 2005 Honda Odyssey
Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Mar 16, 2009 | 2000 Honda Odyssey
Sliding power doors will not open
Just had the same problem with my '05 van. I put the Master Switch in the off position. I pulled fuse #7 on the driver side sub panel, located just above the engine hood release. I then disconnected the neg. terminal on the battery. I manually opened the pass. side slider and closed it.
I reconnected the battery and replaced fuse #7. I put the master door switch in the on position. I activated the auto door switch, and it worked.
Jan 15, 2009 | 2007 Honda Odyssey
My 2000 Honda Odyssey minivan's automatic sliding door on the driver side has stopped working. The passenger side works fine. The fuse is good. I tried a reset process posted online involving removing the...
I had a 2002 Odyssey with the same problem. I cleaned around the micro switch at the bottom rear of the door and checked the door roller bracket screws. The screws were loose so I tightened them and also sprayed the switch with electrical contact cleaner (special stuff that leaves no residue). Apparently this helped the contacts in the switch to close properly and the door was able to reset and work. Good luck.
Dec 27, 2008 | 2002 Honda Odyssey
Honda Odyssey doors
I read about this issue while I was looking for a fix to mine. Try the following:
Remove fuse #13 for 30 seconds or more from the passenger side fusebox. This will reset the door and the clock.
OR
1.) Disable the power door switch on the left dashboard.
2.) Remove the power door fuses located under the front passenger leg area.
3.) Manually open and close both sliding doors.
4.) Restore the power door fuses located under the front passenger leg area.
5.) Enable the power door switch on the left dashboard.
6.) Try opening the sliding doors.
http://www.topix.com/forum/autos/honda-odyssey/TD1QRDMAQ28J8EDA0
Sep 03, 2008 | 2002 Honda Odyssey
Honda 2012 Odyssey EX-L Logo
103 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
