How do I connect an additional monitor to a HP Pavilion Touchsmart 23-F207A?
HP Pavilion Touchsmart 23-F207A All In One Desktop - I would like to use an additional monitor/screen with this PC. I would like to connect my old monitor - HP w2448hc to have the advantage of a double screen. Please assist how & what do I do to make this happen?
  • 198 Answers
SOURCE: Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Posted on Mar 10, 2008
parrotheadpc
  • 2600 Answers
SOURCE: Toggle Between Laptop and Monitor
Fn + F5 toggles the display output, the trick here to wait each time you hit this combination because it goes through several options. Hit it once and it may want to go to just the external, then both the laptop screen and the external. etc. Now Fn + F6 turns the backlight bulb off on the internal monitor to save energy. Now I am giving up the link to your service manual, it is in PDF format so you can make a copy for yourself and keep on the laptop, print it or save it to a flash so you can reference it later. I believe if you take the keyboard off and disconnect the video lead on the left side where the display plugs into the motherboard, then when you power the laptop back up it will default to the external cord and you can use the laptop without any switching. That is what I am doing with an Aspire 5920 that I am rebuilding. Good luck, ParrotHead PC Repair
Just copy and paste the link below to you internet address bar and hit enter.
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
Posted on Sep 05, 2009
jennifer720
  • 830 Answers
SOURCE: manual for hp w2448hc monitor needed, was bought
You can download the manual, specs, etc. here for free:
http://h10010.www1.hp.com/wwpc/uk/en/ho/WF06b/382087-382087-3284302-215012-215012-3454237-3733149.html
Posted on Sep 20, 2009
  • 13 Answers
SOURCE: my HP Pavilion s7210n slimline
the problem is the power supply. it's pretty much a special order part since the slimline case is 'non-standard' . check the link for more info.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1156567&prodTypeId=12454&objectID=bph06788
Posted on Sep 21, 2009
sandro_monte
  • 72 Answers
SOURCE: HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Posted on Oct 11, 2009
What is my IP address to hp touchsmart 610
to find the ip address of your computer do the following. Press the windows key and the R key at the same time. Type CMD in the box that opens. A dos window will open and then type ipconfig and press enter. Your IP addess will be displayed.
Feb 10, 2015 | HP Touchsmart 610-1030y 23" Lcd Desktop...
When i turn on my hp pavilion, the only thing that the screen shows is the time and date?
dear steven,
request you to give a brief explanation of the problem you are facing along with the version of windows.
Feb 03, 2015 | HP Pavilion TouchSmart 23 in. All-in-One...
Hw removing access covers
In general, see this page and select morespecifically the task you wish to perform
http://support.hp.com/us-en/product/hp-touchsmart-520-1000-desktop-pc-series/5146296/how-to?sp4ts.oid=5146296&_op=gotoproduct
If it's just the rear cover, see this page (link from the previous page) EmptyPortlet
Hope this helps
8.March.2015
Aug 31, 2014 | HP TouchSmart 520-1050 PC with 23 Monitor
My hp home computer says monitor going to sleep what are my potions
Right click on your desktop and click properties like you would to change your screensaver.
Click on screensaver and then monitor power,
you will be able to change the preferences there
May 21, 2014 | HP QP790AAABA Desktop Computer -...
How to adjust brightness of monitor on on HP Envy TouchSmart 23 All-In-One?
Try using Fn keys to adjust, otherwise check the setting and control panel applications. Could be something wrong with your power plans as well.
May 14, 2014 | HP Envy 23-1070 All-In-One Desktop PC with...
I want to connect a HP w2207 monitor to a HP TouchSmart IQ770 PC. What is the best way to do this?
Your HP w2207 monitor has support for both VGA and DVI inputs. This therefore means that you can connect your HP TouchSmart IQ770 PC via either of these two connectors.
VGA is the blue coloured port on the rear of your monitor.
DVI is the white coloured rectangular port located on the rear of your monitor.
DVI is the better connection of the two as it is a digital connection, so use this one if you can, alternatively you can use the blue coloured VGA cable to connect your monitor to your computer.
It all depends on which output, either DVI or VGA is found on your Computer. Remember VGA is the Blue coloured port and DVI is the blue coloured port.
All the best!
damnor01
Feb 01, 2011 | HP TouchSmart IQ770 PC Desktop
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
