Tascam midistudio 688 cassette deck problems
Cassette needs to be a special type....when engaged in "play" mode machine shuts off...same with "record" mode...other modes (rw, fw)n are fine....when "arms" are pulled back machine works fine...could it be a the band ribbon?
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Play and recording both are not functioning.
Is not a setting you need to send to repair try contact www.tvps.com they have a icredible special
Mar 23, 2009 | Sony TCM-150 Handheld Cassette Voice...
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
The record mode does not function on the right side.It does play on both sides!
Place the speed on X1 mode to make sure it is off the B mode and it should record.
Jul 27, 2008 | Technics RS-TR373 Single Cassette Deck
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
61 people viewed this question
 Grubhead
Grubhead
