Question about Brother MFC-8460N All-In-One Printer
Connect Unable to print
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Jan 26, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Unable to print through the print server
First, make sure that you can print with the printer connected directly to your computer using a usb cable.
- Make sure the printer driver is installed and you can print with a direct connection
- Get the print server's IP Address, NetGear should have already provided you with this info.
- If your'e using windows xp, go to control panel > printers and faxes
- Right click on the printer icon and go to properties
- Click on the PORTS tab
- Click on ADD PORT
- Highlight Standard TCP/IP Port then click on New Port
- Click next
- Input the WGPS606 IP Address
- Print a test page...
-hope it works!!
Apr 09, 2008 | Office Equipment & Supplies
Brother MFC-8460N All-In-One Printer Logo
16 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
