Question about Home
Cielo tub Hi, I have a Whirlpool Cielo tub and I am having problems with it. I push the button to turn the motor on, which works and motor hums and has power. The problem is, no water is coming out the jets. I can see the impeller on the pump is not turning when I turn the motor on. It does move, but only like 1 cm. Please help to tell me what is wrong and what I need to replace. (I am high in DIY) Thank you
  • 34 Answers
SOURCE: I pushed the on/off button on my whirlpool tub now stuck
The button is normally an air switch. It is attached to a hose that sends the air pressure from you pressing the switch to a pressure activated switch. This prevents you getting a shock since the wiring is at the motor.
First try using something that vibrates to free it up. Just make sure that it's not something that will scratch the button.
If that doesn't work you should have an access panel to the motor on your tub. Pull this off and look for a clear 1/4" poly tube going into an electrical device. Pull the tube off the pressure switch and blow into it to pop the air switch back up.
Posted on Jun 08, 2010
uspartscente
  • 717 Answers
SOURCE: Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
Posted on Sep 06, 2010
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Posted on Nov 24, 2010
packrat1948
  • 528 Answers
SOURCE: How do you change the
Buy a new filter and it will come with instructions.
Posted on Jan 31, 2011
SOURCE: Need an owners manual for a cielo whirlpool tub
my whirpools no have flame
Posted on May 26, 2009
Whirlpool CIELO model J6042 hydro massage bathtub, need owners manual
No owners manuals. they quit making that tub over 6 years ago.
What do you need to know about it?
US Parts Center
Aug 29, 2013 | Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
How do you change the filter in a Cielo jet tub
Jan 31, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jets aren't working. who should i call to fix? a plumber or electrician? can't seem to find a company to service my cielo by whirlpool jacuzzie tub. Txs.
If you can hear the the motor running then call the plumber....if the motor don't run then call the electrician...
Or find someone like me that does it all...:-)
heatman101
Oct 09, 2010 | Whirlpool Home
Daewoo cielo speedo problem
Oh, i had this problem! you need to replace the clock i don't know the name but you need to replace the thing that shows you in which speed you are and the time and things.
Jun 10, 2008 | 1999 Daewoo Lanos
Home Logo
71 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
