Question about Coffee Makers & Espresso Machines
Forester 2006 heater switch not working
Coffee fell on switch, since then does not work
    Top Expert:
  • Coffee Maker... Master
  • 45,144 Answers
The switch may have to be replaced
Posted on Jul 26, 2013
I lost all power except indicator lights when I attempted to start my 2006 Forester
yes check fuses also check the pos+ and neg- battery cables make sure they are clean and put them back on nice and snug
Jun 05, 2014 | 2006 Subaru Forester
Seat Belt Indicator flashes and beeps randomly
If I remember correctly there is a sensor in the seatbelt buckle. It might have worked its' way loose and your leg motions might be moving it enough to open or ground the circuit. Might be a good idea to check and see if something fell into the latch area, too.
Feb 20, 2014 | 2006 Subaru Forester
The power window controls for my forester no longer work. Worked sporadically for a while and stopped altogether. Not hearing any motor noise. How do I remove the door panel and what should I check for?
The switches are self contained and non serviceable so the only thing to do would be to replace the switch, which unfortunately i think your problem is. However it would be a good idea to take the door panels off and check for loose connectors.
http://www.subaruforester.org/vbulletin/attachments/f77/24842d1278866253-removing-interior-panels-stereo-speaker-installation-forester_speakers.pdf
Here is a link to a Subaru Forester owners forum which you can find a wealth of info on (I own an Outback and the forums have saved my behind numerous times). You will have to sign up to view the PDF on door panel removal but its a small price to pay, and hey, it's free. Hope this helps!
Feb 28, 2011 | 2006 Subaru Forester
Subaru forester (2006) radio stopped working - only light static. CD player works fine.
Best guess is the antenna has a broken wire/lead, or somehow got unplugged from the radio. You will have to remove the radio to check antenna wire with Volt/ohm meter.
Feb 27, 2011 | 2006 Subaru Forester
Subaru Forester 2001. Parking lights stay on when car is turned off. Lights go off only when fuse removed. Light switch on steering column was changed to no effect. Separately, AC, fan and heater...
I have had the parking lights on my 1998 forester stay on w/ no way to turn off. Used the remote door lock to lock and unlock car and the lights went off?????????? This has happened twice with the same solution
Nov 26, 2010 | Subaru Forester Cars & Trucks
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
Subaru forester heater
take back to the dealer,hopefully the will find that the blend door cable is off or not adjusted properly
Jun 11, 2009 | 2009 Subaru Forester
I did the initialization as per the directions and the water was hot. When I make the coffee, the warmer button will not come on and the coffee is cold. I turned on the vacation button for 15 minutes...
Sounds like something is miswired from the factory. Note that the tank heater switch on most home brewer models also acts as the "master" power switch. If the tank heater switch is not on, the warmer switch will not work, either - this is normal. Under normal conditions, the tank heater (or vacation switch) should always remain on, except if you are leaving on vacation.
Apr 18, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
15 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
